problem installing greddy bov
Old Dec 25, 2006 | 02:48 PM
boostinjuice's Avatar
okay.. putting it in.. and the boost line for the bov is on the wrong side.. so it puts a pinch or bend in the boost line... how to fix?
Old Dec 25, 2006 | 03:36 PM
bump anyone? can i just unscrew the 5 hex screws ontop and turn it around?
Old Dec 25, 2006 | 03:50 PM
riceball777's Avatar
get a longer boost line
Old Dec 25, 2006 | 08:52 PM
thector1's Avatar
+1
Old Dec 25, 2006 | 09:00 PM
cfdfireman1's Avatar
Remove the top screws and put the barb anywhere you want it.
Old Dec 25, 2006 | 09:10 PM
Cajun Power's Avatar
yes, undo the screws and move the barb where it fits best. Watch out it is under spring tension when u open it!!!!
Greddy BOV's suck by the way. Mine blew up on the dyno...Type s
Old Dec 25, 2006 | 09:27 PM
ries's Avatar
[QUOTE-Cajun Power]yes, undo the screws and move the barb where it fits best. Watch out it is under spring tension when u open it!!!!
Greddy BOV's suck by the way. Mine blew up on the dyno...Type s[/QUOTE]
as long as you recirc the bov you should be OK.....
Old Dec 25, 2006 | 09:43 PM
Danny23's Avatar
how did your bov blow up? i never heard of a bov blowing up.
Old Dec 26, 2006 | 08:52 AM
Well, now I have it all in. Turned the barb around and it is re-circulating, but now it flutters no matter what RPM or boost level I let off or shift at. We [DSM buddy] have tried softening it and hardening it both to the extreme and either one seems to be helping. Any suggestions much obliged.
Old Dec 26, 2006 | 08:59 AM
bvdawg13's Avatar
my greddy rs does the same thing, i believe its normal for this bov...but anyways mine is tightened down as hard as it goes
Old Dec 26, 2006 | 09:00 AM
but that means compressor surge? not good
Old Dec 26, 2006 | 09:03 AM
Smike's Avatar
Ok, did you do the single spring mod? (sorry this is for the TypeS) -- But I know the RS has dual springs - mixed review here though on the single spring mod. Might be worth the try (?)
http://evomoto.com/tech_info.php?tPa...5e2d0b0575aabb
Danny - I have not heard about blowing them up. Melting - yes. I have melted the rubber dia. on the inside before.
Old Dec 26, 2006 | 09:09 AM
Unfortunately, the Type RS. I'm guessing I'm just going to have to deal with this, considering my research has shown that it is a seemingly common problem that almost everyone with the RS has.
Still, any suggestions to make the fluttering less "severe" would be helpful as well. Tighten it all the way down? Or loosen it considerably?
Old Dec 26, 2006 | 09:14 AM
Smike's Avatar
Tightening it more will make the it flutter more. You will have to loosen it up. When I was doing my tuning of the Type S - I went all the way loose then tightened it down a half turn - test drove. Half turn more - test drove, etc...until I was getting fluttering - then I backed it off a 1/4 turn.
Old Dec 26, 2006 | 09:19 AM
MyEvoDream's Avatar
By Fluttering, you mean...letting air/leaking under pressure?
