2.4 Stroker with 35r dyno graph
Old Dec 26, 2006 | 08:17 AM
SwiftEVO's Avatar
Originally Posted by Xska555
nice job! what are some of your supportings mods besides cam & meth inj.?
My setup:
2.4 Block
Manley I beam rods
Weisco 9:1 Pistons
4g64 Cranks
All Clevite Bearings, the good ones before they changed
Arp main, head, and rod studs
Cometic head gasket
Crower spring and retainers
Ferrea 1mm over intake and exhaust valves
Revolver cams
Alky kit
Niesi FMIC
1000cc injectors
AEM Ems, speed density tuned
Fuel rail
Dual walbro inline pump with braided steel lines
Aermotive FPR
Hks Ignition box
Koyo Radiator
Full 3in exhaust, your down pipe, test pipe, and greddy ti catback
Hks EVC 5 EBC
Innovate wideband
DEFI Gauges
Tein Flex coilovers
CCW Sp500 19x9.5 265/30/19 tires
Arc Spark plug cover
Thats what I can think of off the top of my head.
Here are a few pics
--Josh
Old Dec 26, 2006 | 08:20 AM
scorke's Avatar
How much power is to be had over meth and pump with race gas? It seems like your numbers are pretty typical for 35R numbers, although most people run there 35R's on race gas, its gotta be nuts to have that power daily!!! However the tq is what I would really like to see with that 2.4.
Scorke
Old Dec 26, 2006 | 08:25 AM
Rez90's Avatar
how much boost? and how much torque?
Old Dec 26, 2006 | 08:27 AM
scorke's Avatar
Reading>rez90
28 psi, no tq plot because the dyno/tach signal reader was messed up.
Scorke
Old Dec 26, 2006 | 08:28 AM
Rez90's Avatar
needs more boost
Old Dec 26, 2006 | 08:34 AM
SwiftEVO's Avatar
Scorke
The tq was around 495 before the dyno started going crazy and spiking. It said something like 700+. It was doing it to everyones cars. So i guess right around 500 ft lbs.
Its the only car I have so I drive it everywhere. Its so much fun!
--Josh
Old Dec 26, 2006 | 08:38 AM
Rez90's Avatar
what clutch are you running?
Old Dec 26, 2006 | 08:43 AM
SwiftEVO's Avatar
Act street disk with the extreme pressure plate and prolite flywheel.
--Josh
Old Dec 26, 2006 | 08:55 AM
AlwaysinBoost's Avatar
very nice power curve.
Old Dec 26, 2006 | 09:14 AM
Rez90's Avatar
--Josh
wow.....i had the exact same setup and spun the clutch with like 430ft/lbs of torque.
Old Dec 26, 2006 | 09:24 AM
scott yo's Avatar
Very nice! you must be stoked!
Old Dec 26, 2006 | 10:03 AM
TwStDeVo's Avatar
Nice numbers!! also, love those wheels, they look bad a$$ on your car.
Old Dec 26, 2006 | 10:05 AM
Jakeg97's Avatar
looks good
Old Dec 26, 2006 | 11:08 AM
SwiftEVO's Avatar
You had the 3200lb pressure plate? Its rated for 490 ft lbs.
--Josh
Old Dec 26, 2006 | 11:14 AM
Rez90's Avatar
--Josh
sure did. Took a dump on me one day on the highway...................
