mitsu gear oil ?????
Old Dec 25, 2006 | 09:21 PM
xspsi4's Avatar
where is the best or cheapest place to buy this? Would anyone happen to have a part number for this? Also is this the same fluid for the t-case and rear end? 03 5 spd
Old Dec 25, 2006 | 10:52 PM
evo150's Avatar
this is what you need for the front tranfer case and rear diff http://lancershop.com/customer/produ...&cat=15&page=1 you can get a couple of changes out of this jug
Old Dec 26, 2006 | 10:54 AM
sethzx10's Avatar
no....!! <90w heavyduty lucas gear oil > for the rear and mobil 1 <75w/90> for the trans.... 03 EVO
Old Dec 26, 2006 | 12:28 PM
Warrtalon's Avatar
Why did you say that, Seth??
xspsi, if you're referring to just the diffs, then use the Mitsu OEM DiaQueen LSD Gear Oil, and you should buy it at mitsubishiparts.net. Don't buy anything from Lancershop. If you need trans fluid, then get the Mitsu OEM Super DiaQueen 75w/85 also from mitsubishiparts.net.
Old Dec 26, 2006 | 03:56 PM
Barnettevo's Avatar
Warr,
Have you tried to navigate mitsubishiparts.net? I can't get anywhere on that site! Are their prices good?
Old Dec 26, 2006 | 04:01 PM
meanmud's Avatar
Originally Posted by Barnettevo
Warr,
Ah - Mr Barnett - been a while
I just received my DiaQueen 75w/90 from TRE today.
Old Dec 26, 2006 | 04:06 PM
Blue Evo 8's Avatar
I've tasted the diaqueen oil and its nasty
Old Dec 26, 2006 | 04:21 PM
Barnettevo's Avatar
Been lurking mostly , Troy.
Looking to get transfer case (Diaqueen) and tranny oil from the same location to save on shipping-do you know if I can get both from TRE at a reasonable price?
Andy
Old Dec 26, 2006 | 05:17 PM
Evo Girlie's Avatar
TRE????? is that a local shop???? can some1 give me a site or number
Old Dec 26, 2006 | 05:19 PM
Ichigo's Avatar
Go Amsoil. It's the best. Been using it in my Evo with no problems.
Old Dec 26, 2006 | 05:54 PM
Evol.ved's Avatar
Fluid for the five speed tranny is subjective. I use only OEM mitsubishi stuff. Bring your own gallon jug as it comes in a drum to the dealer. As far as I can tell there is no part # for this. 1 gallon costs me 12 dollars. People use BG syncroshift and Redline fluids with great success. The super diaqueen is for the MR six speed ONLY. I do not know how well it works in the 5 speed box.
For the transfer case and rear differential you buy DiaQueen LSD fluid that you at Mitsubishi dealerships for $45-50 dollars. Comes in a can. There is debate on here about this but THERE SHOULD NOT BE. This is the the ONLY stuff for the transfer case and rear differential.
Old Dec 26, 2006 | 05:59 PM
Blue Evo 8's Avatar
+ 1
Old Dec 26, 2006 | 06:18 PM
Yme's Avatar
Yme
+2. you can buy diaqueen at slowboy and lancer shop as well
Old Dec 29, 2006 | 11:16 PM
xspsi4's Avatar
cool thanks guys
Old Dec 29, 2006 | 11:29 PM
Warrtalon's Avatar
No need to get them anywhere besides mitsubishiparts.net. No, the Super DiaQueen isn't only for the 6spd. It just only comes in the 6spd.
