installed new plugs and it got worse
Old Dec 29, 2006 | 01:32 PM
alfmoney's Avatar
ive been having a problem with my car hitting the fuel cut for about 2 weeks now i tried lowering the boost to 17 pounds just to be safe but it still happens, it happend usually 3rd gear wot 4500k. so i did some research and someone said it maybe the spark plugs so i installed new ones today bosch platinum 2 part # 4312 on the box. iafter the install i took the car for a 2 mile drive and it seemed to be running better and ideling better as well. then i tried to get on it after it warmed up and it starting sputtering almost like it was farting with no power at all whats the deal? are these plugs garbage? anyone else using them?
Old Dec 29, 2006 | 01:39 PM
spdracerut's Avatar
Not garbage, but not great either. But since they are new, they should be fine. I'm guessing the gap is incorrect. You're probably getting a misfire/blowout so you'll need to gap them smaller.
Old Dec 29, 2006 | 01:42 PM
smokedmustang's Avatar
Mods help! Do you have the magnacore wires? If so................thats your problem!
Old Dec 29, 2006 | 01:57 PM
brokeazzlos's Avatar
throw away those platinums.
they suck they will cause misfires
either buy stock ones or copper NGK's
never use bosch
Old Dec 29, 2006 | 02:48 PM
jude's Avatar
Platinum will last longer but Copper conducts MUCH better. the spark is probably blowing out...
Old Dec 29, 2006 | 02:53 PM
Apex Racer's Avatar
I use NGK Iridiums, pricey but well worth it IMO
EvoIXMR
Nov 25, 2008 05:59 PM
deadbeatrec
Feb 16, 2008 05:48 AM
BOOSTonHanD
May 28, 2005 02:39 AM
k270kmh
Dec 18, 2004 11:48 AM
bluebanana23
26
Jun 3, 2004 09:59 AM
