royal purple trans fluid?
Old Dec 30, 2006 | 08:04 AM
bomjoon's Avatar
using royal purple tranny fluid ok for the car instead of the Diaqueen?
i tried to get BG sync. but i couldnt get it in time.
they id have pennzoil. but i dont know about the pennzoil stuff.
please help.
if not i'll just use super diaqueen from dealer.
oh and its for a 06 MR.
thanks
Old Dec 30, 2006 | 08:45 AM
RSGuy's Avatar
dia-queen NEVER goes into the tranny. whoever told you that is wrong. dia-queen is for the t-case and the rear diff only. I used Penzoil Synchromesh for my tranny and it shifts like butter. I would have went with BG syncroshift II but Penzoil is much more readily available. I havent heard anything about the royal purple tranny fluid but if its anything like their motor oil, it should work great. Good luck.
Old Dec 30, 2006 | 10:38 AM
94AWDcoupe's Avatar
Royal purple is one of the best oils out. It works far better than GM sycromesh which I used for years till I discovered how good the royal purple works. Royal purple is gl5 and has limited slip additive. It can be used in all the drivetrain parts. Tranny, t-case(incuding LSD) and rear end. The 80-90gear oil is what you want. They make a syncromax specifically for the tranny. But I haven't tried that yet. The 80-90 works VERY well. Shifts a good bit smoother than GM stuff, plus it is a high quality synthetic for superior protection. Pennzoil/GM/ syncromesh is NOT synthetic and breaks down very quickly. The pennzoil is like 5$ a quart. GM charges double for the same product. The bottle doesn't even tell you what the gl rating is. No comparrison between a synthetic and non-syn oil. Those using GM need to try the Royal purple, you wil see what i am talking about.
If you use the diaqueen you should use the GL-5 stuff in the tranny as well.. It is better than the gl-4 the dealer puts in the tranny. The gl-5 has EP "extreme pressure" lubricants which offers superior protection.
Old Dec 30, 2006 | 10:43 AM
vito1's Avatar
Redline always workes..
Old Dec 30, 2006 | 10:46 AM
bluebyu36's Avatar
i heard royal purple is bad for the syncros.use redline!
Old Dec 30, 2006 | 11:53 AM
fryedchikin's Avatar
That is not correct....DiaQueen Super Multi Gear Oil 75W-85 (part # MZ313376) is the recommended fluid for the 6spd MR Transmission.
Old Dec 30, 2006 | 01:24 PM
bomjoon's Avatar
i bought the royal purple Synchromax for $11 @NAPA iguess i'll need 5 of these...
pennzoil was $6 at NAPA.
yeah i heard DiaQueen super gearoil 75w-85 comes w/ our cars from factory.
since i use royal purple engine oil and liked it i thought i would try using one in the tranny.
thanks all for the reply.
(my dealer also said they woud use this instead of the stock one so... )
Old Dec 30, 2006 | 01:26 PM
bomjoon's Avatar
killa i will let you know if the tranny blows. hehe
i dont drive that hard so...
Old Dec 30, 2006 | 03:24 PM
94AWDcoupe's Avatar
Originally Posted by killakilla911
Since when was it that cheap. Ive been to several autoparts stores and shops online and they are about 12.50$ a quart thats the cheapest I have seen it.
discount auto parts has it cheap on the shelf. Royal purple Max Gear is far superior. Dont know where you are getting your info but you need a new source.
Old Dec 30, 2006 | 03:52 PM
o.e.boost's Avatar
^ wait so your using royal purple max gear in the trans and tcase and diff?
--i did my trans fluid change not too long ago with the gm stuff and its better than before...hmm i would like to try syncromax from royal purple too but is the max gear suppost to be used instead of syncromax in the tranny?
Old Dec 30, 2006 | 05:03 PM
Exciting News's Avatar
Anyone use this: http://www.amsoil.com/StoreFront/mtg.aspx ?
Old Dec 30, 2006 | 05:12 PM
bigric09's Avatar
dont use royal purple unless you really like shifting thru mud. i tried it in my 03 and it sucked... i have used redline lightweight as well as bg synchroshift and it has done wonders. stick with those 2 or stock IMO
