what you guys think !! Evo VII
Old Jan 5, 2007 | 02:44 AM
Rutt's Avatar
If you get Jun cams the 264 will be better for street usage. Jun264's perform much better than HKS 272's and slight less than HKS 280's.
Ditch the SARD fuel regulator and go with an Aeromotive, Holley, B&M, BBK or something along that line since they are all very similar. The SARD FPR is an unreliable piece of junk. I have seen several malfunction and I was lucky to notice that mine leaking while the car was idling.
GET the Power FC and then purchase FC datalogit so you can tune the ECU with a laptop instead of the handheld unit. You will need to add a wideband O2 so you can do this properly. Add the boost control function to the PFC and you will have all of theAVC-R's solid boost control perks with the exception of gear based boost control.
There are quite a few twin plate clutches on the market but if you are staying under the 400whp mark all of the companies that make twins also make super singles that are rated to 400whp.
Cusco - super single (made by OS Giken), twin (metal or carbon)
ORC - super single, twin, triple (metal or carbon)
OS Giken - super single, twin, triple (all come in metal or carbon)
ATS - super single, twin, triple (all come in metal or carbon)
ATS makes awesome clutches but I am partial to using ORC or OS Giken clutches. I purposely left HKS clutches off of the list.
The size of the injectors will depend on your intended hp level.
Old Jan 5, 2007 | 03:12 AM
QAT-R's Avatar
Originally Posted by dxbevo8
ahaa...so you are from Oman?? good stuff man..thats like 2.5 hours from dubai where i live...drive down to dubai..i will show you around..i will take you to the evo garage here in dubai...
by the way devil evo...we have ecuflash here in dubai..i would recommend that over the Power FC because the tuner knows what he is doing..he has tuned tons of evos from all over the place...whereis the Power FC is not so populat here..
Good Luck
Im also interested in knowing about this garage in Dubai. How much does it cost for a tune or a clutch job? I'm still debating if I should bring my evo back to Qatar.
Old Jan 5, 2007 | 04:45 AM
dxbevo9's Avatar
the Ecutek Flash is $1100 the first time...and everytime you go back for a reflash its about $500
a clutch install is about $400~300
the garage is called AAT...they are good with ecutek..
Old Jan 5, 2007 | 05:09 AM
Rutt's Avatar
D-JETRO Power FC (uses a map sensor) can be purchased for $900~$1200 and FC Datalogit $350 (serial port) or $375(USB).
Old Jan 5, 2007 | 07:46 AM
Kee1pride's Avatar
do you know what you're talking about? jun's 264 cams profile is much more agressive than the hks280, even at their stage1 (264) camshaft design.
also clutches are rated to handle torque. not horsepower.
listen to the guys telling you to stick with the ecutek flash. although that price is a massive ripoff. its about 600-700 here for first comers.
Old Jan 5, 2007 | 06:00 PM
C1ark's Avatar
Well said
Old Jan 6, 2007 | 12:23 AM
Evo_7's Avatar
Well ur Evo VII is JDM spec rite??
Your stock injectors are 550cc and i do think you will be needing bigger injectors since i also own a JDM EVO VII...And belive me on stock injectors u should check your AF`s...
Also tell me if m rong you will be needing a wide band....
Besides who says Power FC is hard to tune???
Old Jan 6, 2007 | 12:36 AM
jkim2001's Avatar
rutt, you sound like a reliable Japan source. What other JDM parts for the evo are junk? Wow, if I could source Ralliart stuff from you I would appreciate it (I am military). Thanks!
Old Jan 6, 2007 | 12:41 AM
Evo2k6Lee's Avatar
That Evo 7 is the hotness!
Old Jan 6, 2007 | 02:45 AM
Evo_7's Avatar
Yeah and JDM Evo 7 stock is more quicker than stock JDM Evo 8
Old Jan 6, 2007 | 02:59 AM
Ike's Avatar
Ike
Originally Posted by ries
Id say if your always running 95 oct then you can tune the car on 24psi safely...you should not need injectors until you step up to a bigger turbo.
Be careful suggesting that, his 95 (RON) is the same as our 91(PON) and 24psi on our 91 octane isn't such a good idea.
Old Jan 6, 2007 | 03:26 AM
QAT-R's Avatar
Hmmm...I think I know who you're talking about. Is this garage off of Sh. Zaid Road near Emirates Mall? If so, I've met the guy before but his prices were pretty crazy. Does that amount include dyno time?
Old Jan 6, 2007 | 04:41 AM
dxbevo9's Avatar
nope the one off shkh zayed rd is called one thousand dunes garage...yes he tries to rip off people if he senses they are newbies...
the one i am talking about is called AAT (arabian automobile tech.) they are really good..the guy who is running the garage is an ex-tuner/designer of many many quality parts used in race cars in australia...Ivan is his name.
Old Jan 6, 2007 | 04:43 AM
dxbevo9's Avatar
and yes..that price includes the dyno time as well as the tuning
Old Jan 6, 2007 | 05:31 AM
Devil_Evo's Avatar
hey guys I think Apexi Power FC is better for me ... coz in the future I am planning for big turbo (maybe HKS 3240) and my friend told me that ecutek is good for 400hp only ....
So now i decide :
1- APEXi Power FC ... there is many tuners for the power FC here . and its easy to tune.
2- a Double Plate Clutch ...
no need for cams .. maybe in the near future
dxbevo9 ... aha u mean Ivan the australian guy .. 3araftah
now ... I am Planning to run 1.6 boost (I dont think the stock clutch could handle that much of power)
