20G LT, 1st. day review.
Old Jan 14, 2007 | 03:02 AM
  #61
ONRAILS's Avatar
Originally Posted by -=SPECTRE=-
How do you figure it has "stock like spool" when it's hitting peak boost at 5,500 rpm? A stock 9 turbo hits peak boost at about 3,500 rpm.
you don't understanding. Its creeping. Not when it fully spools
A turbo isn't going to take 2,000rpms after 20psi to hit 24.
Old Jan 14, 2007 | 03:20 AM
  #62
BerserkerX's Avatar
I'm tuned for 24psi on pump. Peak torque at 3600rpm, 24psi at 3589rpm. And that's logged w/ a Kavlico MAP sensor, not a palm pilot.
The 20G-LT looks great, but calling it "stock like" based on your logs is simply misleading to those with questions about it.
really according to my logs i am reaching 23 at 3k on my turbo with my tune and i have 91 octane not sure if you are running 93 or not but thats how i am running. I am not sure how to adress you but i guess for what others are calling you mannie great turbo install and it looks nice and i know that it spools like stock it just lasts a lot longer almost as if taper is eliminated very nice write up.
Old Jan 14, 2007 | 08:07 AM
  #63
scottatyamaha's Avatar
Yea it is creep. But even with the adjusment on my wastegate i could not get it to go away. So i am just going to leave it from where i spike to 23psi and creep to 25psi before it settles back 23psi by redline.
Old Jan 14, 2007 | 06:10 PM
  #64
hondafan's Avatar
do you have the optional wastgate actuator?
Old Jan 14, 2007 | 06:53 PM
  #65
If you are asking me I dont just have the stock EVO 9 one on.
Old Jan 14, 2007 | 07:12 PM
  #66
purevibez's Avatar
nice turbo. been thinking about it too. thanks for the info
Old Jan 17, 2007 | 07:55 AM
  #67
El.BlueEvo9's Avatar
What's the update on ur turbo Manie..?Thought u were going to keep us updated.
Old Jan 18, 2007 | 10:46 PM
  #68
04AWDTURBOEVO's Avatar
Almost done with the new set-up Manny. I got two or three more things to do. My new wire boots are coming in on Monday, I plan to degree the cams and crank Wednesday or some time when the Tech is avaliable, and have Jester re-tune my mid-range fuel trims and change to his new designed settings, .
I got to add, the Evo is much more fun to drive now. Torque every where down low, and much more top end. I am very happy with the purchase.
After Sunday, you can start your own Large Turbine Turbo thread, . Your are going to like it alot, .
Old Jan 19, 2007 | 05:05 AM
  #69
Crazy Goat
Old Jan 19, 2007 | 05:20 AM
  #70
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Awesome review Manie. IM torn between this turbo and the stock IX unit. Looks like you have a monster on your hands! Enjoy that sucker
Old Jan 19, 2007 | 06:04 AM
  #71
yellowEVO21's Avatar
You could always buy the IX turbo and if you're not happy, send it in for $1K and get it upgraded.
Old Jan 19, 2007 | 06:13 AM
  #72
dxbevo9's Avatar
what do you mean send it and for 1k you get it upgraded...??
send it where and upgrade to what??
Old Jan 19, 2007 | 06:29 AM
  #73
bwesley82's Avatar
I think Buscher and FP will exchange/upgrade your regular IX turbo to the Green for about $1000
Old Jan 19, 2007 | 06:36 AM
  #74
High_PSI's Avatar
The Issue is removing your turbo, mailing it in, and then waiting to get it back. This is simply not an option for daily drivers. I wish they had a post purchase core exchange, like send the OEM unitback after it is exchanged.
Old Jan 19, 2007 | 12:58 PM
  #75
Faust's Avatar
Well, You are in luck...They do have such a program.
http://linux.forcedperformance.net/m...e=Lancer_Turbo
