boost on evo!!!
Old May 24, 2003 | 01:55 PM
evoinit's Avatar
boost on evo!!!
does anyboidy know if the evo 03 has a factory electronic boost controller trying to instal a tubo xs high performance boost controller
Old May 25, 2003 | 08:20 AM
cdavy's Avatar
Registered User
yes it does. Search on boost selenoid.
Take care,
Chris
Old May 26, 2003 | 02:43 PM
1QWKEVO's Avatar
stock boost solonoid is located under the air box. Solid black hose is the one you want, however you are going to need to re-route the wastegate line to your turboxs and remove the stock T.... Its a deep install those turbo lines are not easy to remove without damaging do to the limited amount of space.
