Fixed Profec B Spec Ii...
Old Jan 11, 2007 | 03:04 PM
dxbevo9's Avatar
Thumbs up Fixed Profec B Spec Ii...
hey guys...thought i would share...
i have read in several threads that people are experiencing boost cut issues with this EBC..
i personally had that problem and was getting frustrated with this...so thought about different settings and solutions...played around with the knob until finally my car runs perfect without any boost cut...
*clarificatoin) Boost cut only occured when i was in high gears low rpms and WOT.
currently i am running 21psi of boost ....
i adjusted "Start Boost" to 1.2 bar...and the "Boost Limited" which reads [ L xx% ] on the screen to 0%.. now my boost hits so so so much harder and faster..and boost holds steady at 21 psi till 7000rpm.. beyond 7k Rpm...it tappers to 20.3..which i am pretty happy with considering my car is not tuned yet.
anyways..this might be not important to many...just thought i would share a solution that worked perfectly and left me satified...
Old Jan 11, 2007 | 04:14 PM
big_huff's Avatar
whats your settings?
Old Jan 11, 2007 | 04:29 PM
dxbevo9's Avatar
my high boost is set at 67%
gain 15%
Set gain 1.25 (x100KPa)
Limiter L 0.0%
hope this helps..it worked perfect for me
Old Jan 11, 2007 | 04:36 PM
big_huff's Avatar
my settings are
set 73%
gain 11%
start boost 12.0psi
when im normally driving at around 4000rpms theres a fluttering sound and my blowoff valve will go off while im still on the gas.
Old Jan 11, 2007 | 04:39 PM
dxbevo9's Avatar
is it a fluttering sound or a Tick tick tick sound?
Old Jan 11, 2007 | 04:45 PM
big_huff's Avatar
like a flutter i havent heard what compressor surge sounds like but from what i read i think its kinda sounds like that.
Old Jan 11, 2007 | 10:08 PM
ihatepotholes's Avatar
set ur start boost at 140... try it
