Questions - aftermarket headers on evo - what about the heat ????? help!
Originally posted by ADMstunna
what kinda of manifold is it? stainless steel? is it an hks or jic one or a custom one? external wastegate? stock location? what turbo's will it bolt up to, what turbo are you running now? pictures? lol. i would really like to see the manifold, thats one of the first custom parts im gonna get when i get started on project 25G evo. you also may just be over worried and actually paying attention to the heat coming from the vent now. cuz mad heat comes from the vent stock already, enough to make me kinda wory bout the paint.
I am going to have a heat shiled made for this header - then have it ceramic coated - I think it will pick up some power and spool up when all that heat which is radiating out of that header stays inside and is sent to the turbo
Originally posted by Alfriedesq
yeah - the thing that leaves the head and goes to the turbo
PS - What about daisy-chaining the AC fan to the other fan so it runs all the time? Or get a fast slimline fan that RRE sells for the eclipse.....it should fit the evo too. The company that manufactures your radiator might have one also.
Its a DN Products header - stock turbo - stock location - I will check again with the heat situation on the stock set up - which I put back in the car last night - - However - the stock set up makes no where near the under hood heat as this header did
Originally posted by liquidlancer
hmm id just wrap it?
maybe just some **** out so you get better airflow through the engtine compartment
To me a custom heat shield and ceramic coating will do the job nicely - - just have to be patient enough to get all the pieces in place
heat shield and coating is the best way to go. may even fool the techs at the dealer
will look super professional. although not all that flashy, i like flashy sometimes. cant wait to see how it comes out.
I plan on getting the factory exhaust manifold cermaic coated as well. I understand that it can reduce turbo lag a noticable amount and reduces under hood temperatures. I might have it Extrude Honed as well...
No way Al's car is going to a dealer for service anyway. Any 5 year old could spot those mods from the window of a jumbo jet at 25,000'.
Originally posted by Zeus
Get it coated... Swain Tech, Jet Hot, pick your poison. I'd go with nothing less than the 2000 degree coatings.
So, what header you running? Come on, give up the goods!
might want to look at http://www.hpcoatings.com also...
Question: A non-coated header replacing a factory exhaust manifold will allow the heat from the exhaust to disapate better (thinner walls), hence the increased heat coming from the hood vent. Why would you want to put the heat back in to your exhaust by coating the header. The heat difference between the two (coated, non-coated) is several hundred degrees. The more heat you can get rid of before it reaches the exhaust side of your turbo, the better, right? This would ultimately lower the heat on your intake side of the turbo and also lower the heat entering the intercooler. Your motor (HP, TQ) benefits from a cooler intake charge. If you've notice in some of the European magazine's, a lot of the extremely high HP EVO's (turbo car's), the header is not coated and takes on a rust color. Myself, coming from NA motors, coating the headers takes the heat away from the engine compartment and the air intake. NA motors benefit from keeping the heat in and out the header, so coating is a benefit. Turbo cars? Am I missing something?
