Dynoed 100 octane!!! ### inside...
Old Jan 13, 2007 | 02:20 PM
ant_turbo's Avatar
Mods at the time of dyno..100 Octane race gas and 25.5.psi
255 F/P,3' CAT DELETE,3'CATBACK,INJEN UICP WITH HKS FILTER,MBC,ARP HEAD STUDS,
359.HP and 353.TQ
Old Jan 13, 2007 | 02:32 PM
Recks's Avatar
What was it before the 100 octane?
Old Jan 13, 2007 | 02:34 PM
KOEvo's Avatar
Sounds about right.
Got a Tantrix cable? Log knock counts and turn it up to 30 psi.
I logged and couldn't turn my stock turbo up enough to knock on 100 octane, i ran like 27-28 psi with no knock. Now that's when my VIII turbo maxed out, so i didn't push any more hot air, but if i had a IX turbo i would turn it up to 30 psi, personally.
Maybe you'll make 380...
Old Jan 13, 2007 | 02:40 PM
Pure Playaer's Avatar
What psi?
nvm 25.5
use higher octane, n turn that boost up! lol
Old Jan 13, 2007 | 02:44 PM
cij911's Avatar
359.HP and 353.TQ
Holy Cow Batman -- 3 foot diameter TP and catback ..... WOW... j/k
Nice numbers...I am running 24/25 psi peak and tapering to 22 psi redline (using ECU / BCS), I wonder if my numbers are similar...You probably are running more timing....Any idea what timing you hit at redline? Congrats!
Old Jan 13, 2007 | 02:57 PM
dafunk630's Avatar
looks good!!
Old Jan 13, 2007 | 03:03 PM
ant_turbo's Avatar
A few months ago with only a 3'catback,mbc,hks open filter and 20psi/91 octane I dynoed 301HP,,,
I need to do a few evoscan logs on the 100 octane race map....
Old Jan 13, 2007 | 03:16 PM
Recks's Avatar
Awww good jump eh..
Old Jan 13, 2007 | 03:50 PM
1NASTYIXMR's Avatar
great numbers
Old Jan 13, 2007 | 04:09 PM
3SgteGuru's Avatar
Thats pretty Sick, too bad 100 octane is soo hard to get and its soo expensive around here.
Old Jan 13, 2007 | 06:41 PM
cij911's Avatar
Ant -- Can you run Alk in Cali and get about the same results? We will likely be moving back to Cali. and I cannot imagine detuning my car from 93 (I am currently contemplating Meth. kit w/ 93)....
Old Jan 13, 2007 | 06:56 PM
nj1266's Avatar
Ant--Weren't you the one who had a knocking car and posted about in the Ecuflash forum. How was that resolved?
Old Jan 13, 2007 | 08:52 PM
mdog's Avatar
Looks like spinning it past 7k doesn't net you anything. At least you know where you can shift at. Nice #'s and keep it safe if you decide to turn up the whick.
Old Jan 13, 2007 | 09:37 PM
ries's Avatar
nice #'s...are you still on the stock dp???
Old Jan 14, 2007 | 12:44 AM
ant_turbo's Avatar
Installed my 3' megan DP..
