weird rain issue anyone have this happen?
Old Jan 13, 2007 | 03:07 PM
turbotekray's Avatar
well today my wife came home saying her car breaks up under boost, so i drove it and it breaks up very bad. so 1st thing i do is check the plugs. cylinder one was full of water not inside the head but on the top part to the point the plug was submreged. i took my shop vac and vacumed the water out and was able to get the plug out with out water going into the head . so i checked 234 and they were fine no water. my question is how the hell did water get in there. so i replaced the plugs with oem plugs, take the car on a test spin and it still breaks up.... anyone have this happened before or have any ideas.
Old Jan 13, 2007 | 03:09 PM
hotrod2448's Avatar
My question is which car is hers? The Evo or the STI?
I would venture to say it is coming in through the hood vent.
evo of course
Old Jan 13, 2007 | 03:11 PM
4WS Tuning's Avatar
over boosting?
did yout log it?
Old Jan 13, 2007 | 03:15 PM
hotrod2448's Avatar
Originally Posted by 4 Wheel Slide
over boosting?
did yout log it?
Did you read what he wrote? It was full of water and probably shorting the plug out. Spray it down with some silicone or WD-40.
I have never had that much water get into my engine bay. Did she follow something through a big puddle and it splash up and into the hood vent or something? Are you running the factory plug wires? It would seem really hard for water to get down in there with the stock wires sealing it off the way they do.
Old Jan 13, 2007 | 03:18 PM
no puddles, i thought the plug shorted out , thats why i replaced them. but still breaks up. car drives perfect undr regular driving..
Old Jan 13, 2007 | 03:19 PM
oh yeah stock plugs and wires
Old Jan 13, 2007 | 03:23 PM
4WS Tuning's Avatar
ya buddy i read perfectly fine..... he's still having problems.... my gauge was off and i was running 25 pounds instead of 21 pounds and the car drove like crap and i couldn't figure out why..
Old Jan 13, 2007 | 03:24 PM
its not over boosting, im running 22 psi.
Old Jan 13, 2007 | 03:35 PM
8urv8's Avatar
Who knows for sure. Maybe through the intake somehow? I had a friend with a Jetta 1.8t. He had cold air intake that had the filter positioned pretty low in front of the wheel. He drove through a really deep puddle sucked up some water.
Old Jan 13, 2007 | 03:37 PM
nah its a stock intake, everything is dry , besides the water was on the upper part of the plug
Old Jan 13, 2007 | 04:16 PM
ok so i sprayed some wd40 on the inside of the wire got the connection cleaned out, went for a ride after 3 mins of trying to get into boost, the break up became less and less, after 20 mins the car is going into boost again and not breaking up. i assume something was still a little wet and after a nice ride it evaporated.
Old Jan 13, 2007 | 04:21 PM
hotrod2448's Avatar
I just thought that it was weird that you immediately went to an overboost issue when he led us to believe the car runs fine normally and only started breaking up after it got wet.
Old Jan 13, 2007 | 04:24 PM
3SgteGuru's Avatar
Now your problem isn't fixed, as a mechanic I have learned (the hard way) things don't break themselves (usualy). I am assuming you mean the water was above the plug in the spark plug access tube, where the spark plug wire boot goes. So the way the water must have got in there is from the top of the spark plug boot. Make sure They are sealed very well against the valve cover. I see this happen alot.
Old Jan 13, 2007 | 04:28 PM
yeah water was above the plug in the access tube, everything is all sealed now!!!!!!! must not have sealed good when i changed the plugs last month
