Forge wastegate actuator or Buschur's high boost wastegate actuator
Old Jan 22, 2007 | 08:42 PM
Deepseadiver's Avatar
can the stock wastgate be "preloaded" to hold more boost? I am running meth and the 20G-LT turbo, boosting to about 29PSI and tapering very bad. What are the pro's and con's of getting a better wastgate?
Old Jan 23, 2007 | 08:51 AM
Mike@Forge's Avatar
Yes, it can, but to a very limited amount.
You're still limited to a stock actuator spring pressure of around 12-14 PSI, whereas our actuators come with a much higher base setting, but we also have customizable spring rates available too.
Old Jan 24, 2007 | 09:16 AM
Just ordered the Forge unit! should be here tomorrow!
Old Jan 24, 2007 | 09:56 AM
TURBODAWG's Avatar
Get an RPM based boost controller and you can dial the taper out some. You should be able to dial out some if not all of the taper. Probably wont hold 29 psi to 8k without an upgraded actuator though.
Brian
Old Jan 25, 2007 | 02:19 PM
who makes a rpm based boost controller. an EBC?
Old Jan 25, 2007 | 03:24 PM
TURBODAWG's Avatar
I know of several. Apexi AVC-R, Greddy E-01, HKS EVC 6. There are several others as well also.
We were able to hold 28 psi to 7700 RPM on a Evo 9 WR turbo with an HKS EVC 6.
Old Mar 13, 2007 | 06:07 PM
Chris Pana's Avatar
hey turbodawg, I currently have the same ebc the hks evc vi, can you share any tips on how you get it to hold smooth boost etc. The guys here in Aus are a little unsure of hwo to set this puppy up since it's so new
any help would be awesome!
Old Mar 14, 2007 | 05:53 AM
TURBODAWG's Avatar
I sell a supplemental, highly detailed 5 page setup manual for the Evc 6. It goes into detail on the somewhat complicated initial setup, as well as specifics to get rid of the taper on stock turbo Evos.
PM sent.
Brian
benIX
Feb 21, 2014 04:21 AM
joeymia
88
Dec 20, 2009 06:30 AM
LetsGo82nd
May 26, 2009 08:38 AM
EE
11
Jun 16, 2008 08:16 PM
unknown2
15
Sep 8, 2005 04:02 PM
