tuning for 110 oct?? lean it, more timing?
Old Jan 18, 2007 | 03:05 PM
4WS Tuning's Avatar
right now i have a jestr 93 octane map and i plan on going to the track tomorrow
i usually just toss in some 110 and turn up the boost to 27/28 pounds.
i finally have a wideband but im not sure how the car actually reacts to race gas on high boost
how do people make more power on race gas? just from turning up the boost?
or do i add a count or 2 of timing. lean the fuel, add more fuel?
I WANNA GO FASSSST!!!!
I MISS YOU MAMA SPEED!
-Ricky Bobby lol
cheers!
Old Jan 18, 2007 | 03:46 PM
Jasil's Avatar
I do it the risky way....just add timing and lean it out and make a pull while either myself or a friend is looking for knock on the laptop. I bought a 100 octane e-flash from TTP which made a difference on the butt dyno have not been to the track, but the ever so trusty G-tech (a friends and yes I'm joking about ever so trusty) has the car trapping a extra 2-3mph over the 93 octane map.
Old Jan 18, 2007 | 03:55 PM
4WS Tuning's Avatar
i figured i'll drop all the fuel .2 or .3 and add a count of timing
on 93 my a/f is 11.1-11.3
Old Jan 18, 2007 | 04:03 PM
4WS Tuning's Avatar
i also have a meth map for my car.... ya think that would work?
heres from 200-340 load from 2500-7500
11.7600 11.4732 11.2000 10.8138 10.5708 10.3385 10.3385 10.3385
10.1708 10.0085 10.0085 9.95556 9.90316 9.90316 9.90316 9.90316
9.36119 9.31485 9.74922 9.85131 9.95556 9.90316 9.90316 9.90316
9.60000 9.50303 9.50303 9.74922 10.0085 9.90316 9.90316 9.90316
9.60000 9.45528 9.45528 9.45528 10.0620 9.95556 9.95556 9.95556
9.85131 9.74922 9.64923 9.64923 10.1708 10.1708 10.1708 10.1708
9.95556 10.0085 9.90316 9.90316 10.3956 10.3956 10.3956 10.3956
10.0085 10.0085 10.0085 10.0085 10.5708 10.5708 10.5708 10.5708
10.0085 10.0620 10.0620 10.0620 10.6305 10.6305 10.6305 10.6305
10.5117 10.4533 10.3385 10.3385 10.9395 10.9395 10.9395 10.9395
10.5117 10.4533 10.4533 10.4533 11.0682 11.0682 11.0682 11.0682
Old Jan 18, 2007 | 04:13 PM
4WS Tuning's Avatar
does the other one look okay to run 110.... or should i use this map as it is... or lean it out by .1 or .2
and this is my 93 fuel
200-340 load and 2500-7500 rpm's
9.36119 9.22353 9.22353 9.22353 9.13398 9.13398 9.13398 9.13398
9.36119 9.31485 9.31485 9.31485 9.22353 9.22353 9.22353 9.22353
9.60000 9.50303 9.50303 9.50303 9.40800 9.31485 9.31485 9.31485
9.60000 9.45528 9.45528 9.45528 9.45528 9.36119 9.36119 9.36119
9.85131 9.74922 9.64923 9.64923 9.55127 9.55127 9.55127 9.55127
9.95556 10.0085 9.90316 9.90316 9.80000 9.80000 9.80000 9.80000
10.0085 10.0085 10.0085 10.0085 9.90316 9.90316 9.90316 9.90316
10.0085 10.0620 10.0620 10.0620 9.95556 9.95556 9.95556 9.95556
10.5117 10.4533 10.3385 10.3385 10.2261 10.2261 10.2261 10.2261
10.5117 10.4533 10.4533 10.4533 10.3385 10.3385 10.3385 10.3385
Old Jan 18, 2007 | 04:15 PM
Boltz.'s Avatar
FCOTM Winner
In the load cells that count (the ones you hit while drag racing) take out .3 of fuel (so technically increase the number .3, since were talking about ecuflash) and add 3 degrees of timing. You'll be fine.
Old Jan 18, 2007 | 04:16 PM
4WS Tuning's Avatar
should i do that with the meth map or 93 map?
Old Jan 18, 2007 | 04:35 PM
4WS Tuning's Avatar
bump
Old Jan 18, 2007 | 06:32 PM
4WS Tuning's Avatar
bump
Old Jan 18, 2007 | 10:56 PM
4WS Tuning's Avatar
fggw!
Old Jan 19, 2007 | 12:10 AM
4WS Tuning's Avatar
Old Jan 19, 2007 | 03:07 AM
kjewer1's Avatar
I usually lean out to around 12:1, and add a good bit of timing. I run 117 octane leaded, and I find that that **** doesn't like to burn or something. I have to add a good bit of timing. Race gas doesn't knock easily, so you can typically keep increasing timing until you reach the point of deminishing return.
Old Jan 19, 2007 | 06:39 AM
matt55's Avatar
So does 3* more timing sound like alot on 110(from a 93map) ?
Old Jan 19, 2007 | 06:41 AM
kjewer1's Avatar
That would be on the conservative side, but certainly not an unreasonable starting point. IMO, YMMV, etc, of course.
Old Jan 19, 2007 | 08:56 AM
matt55's Avatar
4 wheel - i dont mean to keep asking questions in your thread . But i also run 110 at the track (i get it for $4.50 a gal) and ive been wanting some info on this as well . Iam starting to change over from the flash/AFC to just using ecuflash
kjewer1 - Wow that seem like alot , isnt 1* of timing about -/+ 10hp ?
and since iam hijacking 4 wheel thread so nicely how much more hp could one look at when using a afc set at -7% (my 118mph run) VS +3* of timing and -.2 on the fuel on ecuflash....20hp??
