Help please with intercooler piping !!!
Old Jan 24, 2007 | 04:06 PM
whitersevo's Avatar
Ok well, I have t-BOlt clamps on my car, and I keep blowing it off the intercooler connected too the manifold..... boost is set at 22 psi what do you think I should do, I wasnt having this problem on the dyno...
Old Jan 24, 2007 | 06:25 PM
dafunk630's Avatar
damn...i dont even have t-bolt clamps on my UICP and my UICP dont pop off an im running 28 psi. if i were u i make sure u have it installed right
Old Jan 24, 2007 | 06:26 PM
whitersevo's Avatar
hmmm your funny it only goes on one way
Old Jan 24, 2007 | 06:58 PM
DWAIST's Avatar
you sure it's not in a bind some where? are the ends of the pipes rolled/beaded?
Old Jan 24, 2007 | 06:59 PM
dafunk630's Avatar
thats funny!!!!
Old Jan 24, 2007 | 07:01 PM
bvdawg13's Avatar
intake manifold?? thats the last place i have seen a pipe blow off
Old Jan 24, 2007 | 11:42 PM
mitsuorder's Avatar
When I tried using a Breeze t-bolt clamp from napa to secure my stock upper i/c rubber hose to my throttle body it kept blowing off no matter how tight I got it. I believe that if the t-bolt clamp is too wide to catch on the lip recession of the throttle body not allowing the upper i/c hose to properly seat. Find an upgraded clamp closer to the width of the stock worm gear clamp. Also if you want to try and make the t-bolt clamp work again, spray some Aquanet Ultra-hold hair spray on the inside of the stock i/c hose before clamping it down
Old Jan 24, 2007 | 11:46 PM
eponti's Avatar
a can of hair sray works too
