Strange boost problem
Old Jan 25, 2007 | 11:56 AM
kmcconn9's Avatar
It's not the Hallman making it only go as low as 22psi - that would be the wastegate, imo. MY Hallman set to minimum gives me base wastegate pressure = 11psi.
So the question is what spring is in the wastegate when its shipped from Buschur....probably the heavy spring(s)
From looking at the Spring pressure chart on Tials site, it looks like the heaviest spring is 20.305psi......interesting
http://www.tialsport.com/documents/w3_tial_44_sp.pdf
edit: just contacted Tial to see what the standard spring they come with out of the box...
Old Jan 26, 2007 | 06:43 AM
kmcconn9's Avatar
Problem solved: I changed the plugs this morning with a fresh set of BPR8ES's gapped to .024 and she pulls hard at 24lbs as long as i want...
