IX w/GSC S1 cams & meh - Need Injectors?
Old Jan 25, 2007 | 12:36 PM
dennyt4's Avatar
I have a IX with an SMC kit waiting to go in, and I would like to also go with a set of GSC S1 cams, but my question is, will I need a bigger injector than stock? I don't know at what point I would need to upgrade them, so any advice is appreciated.
Thanks
Old Jan 25, 2007 | 12:42 PM
Ultimate CC's Avatar
with meth you shouldn't have an issue...on pump gas alone you will likely be maxing them out...
Old Jan 25, 2007 | 12:47 PM
dennyt4's Avatar
OK, thanks. Is there anything else I should need if I have...
TBE
MBC
Injen Intake and hard upper pipe
Walbro
ARP headstuds
SMC Meth running either straight meth or 75/25
GSC S1 cams
Should I add a ported stock exhaust manifold and O2 housing, or LICP? Not sure if they are worth the time/effort. I do run a HFC, so those few HP aren't worth it to me, so that's why I'm not sure of these last few pieces.
Thanks
Old Jan 25, 2007 | 12:49 PM
I am not a fan of the ported or after market manifolds or o2 housings but people here tend to be...the licp is a nice easy upgrade though...
Old Jan 25, 2007 | 12:52 PM
dennyt4's Avatar
Thanks for the advice
Old Jan 25, 2007 | 01:31 PM
dafunk630's Avatar
mine are maxed out... next im doin precision 680cc and 20glt
Old Jan 25, 2007 | 01:53 PM
dennyt4's Avatar
Are you running 100% meth? Also, do you run a colder spark plug or any kind of ignition system booster?
Thanks!
Old Jan 25, 2007 | 01:58 PM
I would run one step colder and im not a fan of 100% at most i would run is 75%, no need for 100%...
Old Jan 25, 2007 | 02:04 PM
dennyt4's Avatar
Yeah I was leaning to 75/25 mix, and to be honest I may even have a map on 50/50 if I go with cams. I ran 50/50 in my last IX & Snow kit , it made a very nice daily driver, and would have gone Snow again, but I got a great deal on the SMC kit I got.
One other question about meth...If you run race gas along with meth - say for a track night - can I go higher boost/timing, or is there a point of diminishing returns? Just something I was curious about.
Old Jan 25, 2007 | 02:14 PM
you will see minimal gains with race gas and meth on stock turbo, there is only so much you can push it...there are other additives to make more power but i haven't done enough personal testing with them to suggest it yet...
Old Jan 25, 2007 | 02:16 PM
dennyt4's Avatar
Gotcha - that's what I was thinking.
Yeah I don't enough about it either to even give it a shot.
Old Jan 25, 2007 | 02:17 PM
boomn29's Avatar
+1. Any way to straighten out and increase airflow through the car is beneficial. It's also a cheap and easy mod as stated!
