boost gague busted or need to turn the boost down?
Old Jan 25, 2007 | 07:52 PM
filter's Avatar
ok when i WOT my boost jumps to 23-24 pounds peak then goes stragiht to about 20.5 21 where it should be and holds it there with small taper to redline.
is my gauge just bounching to 23-24 pounds or am i really hitting 23-24 pounds psi?
i have a defi boost gauge.
Old Jan 25, 2007 | 07:56 PM
whitersevo's Avatar
I believe your hitting 23-24 psi for bout a second, boost spike all evos do it..
Old Jan 25, 2007 | 10:05 PM
rchristie00's Avatar
totally off topic, im about to buy the glowshift gauges, boost a/f .. does n body have those?, i know theyre kinda cheapy .. thats why im hesitating .. so please help a brother out
Old Jan 26, 2007 | 04:54 AM
steevo's Avatar
are you using a boost controller? if so, which one?
Old Jan 26, 2007 | 05:00 AM
Greg K's Avatar
it's just a boost spike. you're fine.
Old Jan 28, 2007 | 07:33 AM
filter's Avatar
im using the forge.
Old Jan 28, 2007 | 07:35 AM
9sec9's Avatar
I agree with Greg K. Which turbo are you using and which actuator?
Old Jan 28, 2007 | 09:09 AM
19psi's Avatar
I see you're in NY.
In cold weather, the boost will spike a bit higher due to the colder air (our cars love cold air).
If it's a spike, I wouldnt worry about it too much.
I run 22lbs daily but I've seen some spikes as high as almost 24 lbs recently due to extremely cold weather.
It's not a biggy man.
