How many 6 speed owners would put this in their tranny?
Synthetic Manual Transmission and Transaxle
Gear Lube 75W-90 API GL-4 (MTG)
I couldn't copy the link from Amsoil's website but you can find it under their products: www.amsoil.com.
On the site it says:
Recommended for synchronized manual transmissions and transaxles that require 75W-85, 75W-90 or 80W-90 viscosities and any of the following performance specifications: API GL-4 and MT-1, ZF TE-ML 02B, 16A, 17A and 19A, Chrysler MS-9070, MAN 341 ML. Recommended for use in NV 4500 transmissions, and replaces GM part #12346190 and Chrysler part #4874459.
This is probably the closests equivalent I've found for the Super Diaqueen OEM stuff.
Also for the people who's changed the oil in the 6 speed, what size allen socket did you use? TIA
I will may be try it as transmission fluid but not for transfer case or rear differentials... How many miles do you have on your MR? If it is not near 30K miles, I would just change "TRANSFER CASE" and "REAR DIFF" with Mitsu LSD oil...
Amsoil makes amazing quality products, thats what im currently running in my 5 speed. I dont know if theres a difference in fluids required between the two, but for what its worth, I have never had a problem with any of there products.
I wish they sold that stuff by quarts
Like I said, OEM for me. Even if the AMSOIL stuff meets the specs, trannies are particular about their juices, and the only guaranteed, no doubt about it, perfect match is the
products.
But that's just me. Other folks run other fluids and couldn't be happier. Of course, some regret trying non-OEM fluids, too.
products.But that's just me. Other folks run other fluids and couldn't be happier. Of course, some regret trying non-OEM fluids, too.
I like to go OEM because I want to pay more $$$$. I don't want the cheap stuff.
