Piping blowing off
Old Jan 27, 2007 | 08:10 AM
Mitsu3's Avatar
Piping blowing off
Do the brackets on the stock licp prevent the piping from coming off under boost b/c i put the bushur and i feel like it could blow off easy and i put it tight. Should i put the stock one on or is it fine?
Old Jan 27, 2007 | 08:13 AM
JoeyM3's Avatar
get some t-bolt clamps, you should be fine aftere those
Old Jan 27, 2007 | 09:01 AM
Mitsu3's Avatar
should i order them from lancershop and what size for the bottom and what size for the turbo outlet?
Old Jan 27, 2007 | 09:04 AM
Mitsu3's Avatar
also do i need them for the upper or just the licp
Sap12687's Avatar
If you want, spray a little hair spray on the piping then slide it on and tighten the clamp. I heard it works.
Old Jan 27, 2007 | 12:21 PM
drewblueeye's Avatar
everyone says get T-clamps, which i am not saying that they dont work cuz i am sure they work fine. But if you want to make 100% sure that the pipe wont blow off do what i did.
Go to the Deisel supply shop, buy clamps for a turbo deisel F-350 pickup. i have attached a picture of them. these WILL NOT leak or come off, lol.
Its like killing a rabbit with a hand grenade. Over kill. But i would rather be safe then sorry.
Old Jan 27, 2007 | 12:26 PM
evo ippo's Avatar
NAPA and you could search for tbolt clamps and find the correct size.
FYI upgrade to silicon couplings too the factory stuff tends to expand under high loads
Old Jan 27, 2007 | 01:29 PM
LoCo4's Avatar
I got those.....they are called constant torque clamps. They are used in high boost turbo diesel applications.
Old Jan 27, 2007 | 02:59 PM
Robevo RS's Avatar
i never had this problem
Old Jan 27, 2007 | 08:06 PM
Cedricredrs's Avatar
I tried to buy one of those clamps for my intake manifold throttle body and I havnt changed it yet becuase I've been too paranoid about crushing the throtle body on the intake manifold...I don't know how tight to tighen it and its annoying when it blows off under full boost on the freeway....any advice???
Old Jan 27, 2007 | 08:37 PM
mrfred's Avatar
You're not going to crush the throttle body. Use hair spray for the install, and as you tighten the t-bolt, you'll want to stop when there is a rapid change in the amount of force required to continue tightening the t-bolt.
Old Jan 27, 2007 | 08:51 PM
ptevo03's Avatar
NAPA has both t-bolts and the other one in the pic, just get them to let you look at the pics in there book. I have seen both of them in there.
Old Jan 27, 2007 | 09:04 PM
HmanEVO's Avatar
If you're having trouble locating some t-bolt clamps this is a good site. http://www.siliconeintakes.com/ I've ordered from them twice now. Good pricing with quick shipping. Can't go wrong.
Old Jan 27, 2007 | 09:05 PM
Ultimate CC's Avatar
t bolts ftw...
Old Jan 28, 2007 | 09:25 AM
Are t bolts easier and safer to install than the spring loaded turbo dielsel clamps, on the intake manifold throttle body without having to worry about breaking anything? Thanks
