Triple Intank Walbro??
Old Feb 1, 2007 | 07:08 AM
FullBlown's Avatar
Originally Posted by gsnt
Not to mention the fact that when the tailshaft breaks on a 1000+whp car and sends the driveshaft almost thru the floor where the stock gas tank resides. I'm sure glad I had a fuel cell that day.
Nice looking piece though. Whats the coin for that unit?
Well, this was custom for Julio If we build more triples they would go for around $550
Originally Posted by DarkMastyr
With this, your fuel gauge will move as quickly as your tachometer when you gas it...
Old Feb 1, 2007 | 08:44 AM
CO_VR4's Avatar
I only see two pump fittings on the top flange. Does the third pump have its own separate fitting?
If you need the pumping capacity of three walbros, I'd think that a more beefy entire system would be required...
Old Feb 1, 2007 | 08:51 AM
jmartinez1170's Avatar
Its called a tune. The 2nd and 3rd pump wont come on untill there needed when driveing around or racing.
Old Feb 1, 2007 | 08:53 AM
This could happen to any car 600whp and up.
Old Feb 1, 2007 | 09:17 AM
FullBlown's Avatar
They are all fed into a 1/2" port and then out to a AN line. Not every pump have its own oulet
Old Feb 1, 2007 | 09:26 AM
Nesiop's Avatar
Wouldn't a dual pump with a single inline be more efficient?
Old Feb 1, 2007 | 09:51 AM
When you maxx out the dual setup the 3rd pump takes over. Its all in the tune im not going to give it all away but you should get the idea.
The main reason i didnt go with a ext. fuel pump like a weldon or a fuel cell. I want to keep the noise down. This will still be a street car for a few months after a get it back.
Old Feb 1, 2007 | 02:43 PM
FullBlown's Avatar
Post pics asap! Im glad to be apart of your mission Julio. cheers bro
Old Feb 1, 2007 | 02:48 PM
TrinaBabe's Avatar
Running that much gas through a -8 port doesnt seem right. I would have personally ran it through at least a -10. Nice unit though!
Old Feb 1, 2007 | 10:29 PM
Rcebowl's Avatar
ehh nvm
Old Feb 2, 2007 | 06:46 AM
jbrown's Avatar
I just realized that 3 walbro 255's will flow 480lb/hr @ 100psi, but with only 2 of the Buschur modified pumps you would get 500lb/hr.
It wouldn't matter unless you were running over 40lbs of boost, but it is something to keep in mind.
Old Feb 2, 2007 | 07:40 AM
FullBlown's Avatar
There is a reason why the modified pumps hold alot better up top and theres a reason why the regular ones dont. I am almost positive i know how the modified ones work but with respect to David Ill keep that to myself, otherwise it could open a big can of worms.
Old Feb 2, 2007 | 07:49 AM
David Buschur's Avatar
julio,
We are having a race here in June and August. AMS will be here I am sure along with us of course. Bring your car chase the number.
Old Feb 2, 2007 | 07:58 AM
FullBlown's Avatar
Originally Posted by davidbuschur
julio,
I think its time for me to take a vacation
Old Feb 2, 2007 | 08:16 AM
DynoFlash's Avatar
Ill tell you right now hp is only a number if you cant put it to the ground its pointless.
But i will chase the number and yes i will smash it.
I love your approach - walk softly and carry a big stick - fascinating
