Clutch install
Old Jan 31, 2007 | 08:09 PM
Jspec EVO VIII's Avatar
Clutch install
Alright guys getting my new Exedy twin HD w/ss clutch line installed within a week or so. So should i just stick w/ the oem fluids for the Tranny fluid? Is there any other fluids i gotta worry about changing also? Heard i should do the T-Case as well Plus I'm pondering if i should take out the restrictor pill or not. What do you guys think?
Old Jan 31, 2007 | 08:17 PM
more everything's Avatar
Do your research. It took me a long time to choose the right tranny fluid(MT-90). Use the stock Diaqueen fluid for the T-case and R-Diff.
Old Jan 31, 2007 | 08:39 PM
I've read some things about the Redline fluid, some say its good, some say not so good. Just wanna make sure all goes well.
Old Jan 31, 2007 | 08:45 PM
Cirrusly Evolvd's Avatar
Use Redline MT-90 or BG Syncroshift II. That is what's recommended by TRE and Shep Racing who build Evo transmissions for a living.
For the Transfer Case and Rear Diff they recommend the OEM Hypoid Gear Oil or Redline Heavy Shock Proof.
Old Jan 31, 2007 | 08:47 PM
Ultimate CC's Avatar
redline mt90 for tranny will be the only fluid going in mine...
