oxygen sensor plug answer
Old Feb 1, 2007 | 02:32 PM
Mitsu3's Avatar
if any of you with the IX want to plug up the bung for the ox. sensor on your new catback i found that you need a 18mm drain plug that will fit. jsut wanted to let you know.
Old Feb 1, 2007 | 03:27 PM
kjewer1's Avatar
I wasn't aware this was an area of confusion, but NAPA offers an actual O2 sensor plug. M18x1.5 IIRC. About 2 bucks.
Old Feb 1, 2007 | 05:14 PM
Neuspeed06's Avatar
I used a 1978 Ford truck spark plug before i got the proper nut from the seller. Worked just fine.
Old Feb 1, 2007 | 05:21 PM
CoreyR's Avatar
The 18mm thread size is pretty common for most spark plugs, O2 sensors, drain plugs...
