Radiator which one ?
Old Feb 2, 2007 | 05:02 PM
blackonblackevo's Avatar
Is it safe to buy a ebay radiator, if so which one should i purchase ? Does anybody have any experience with ebay radiators?
Old Feb 2, 2007 | 05:36 PM
Piper's Avatar
Why are you looking at purchasing a new one?
Did something happen to your original radiator?
Old Feb 3, 2007 | 04:07 AM
I want to max my cooling efficiency.
Old Feb 3, 2007 | 04:17 AM
sparky's Avatar
Do the Ralliart 170*F. thermostat and also the coolant line bypass mod to the throttle body. I like the PWR aluminum radiator. Is your car already equipped with a coolant temperature gauge. If not, get the 42 Draft Designs thermostat housing with coolant temp sensor fitting.
Old Feb 3, 2007 | 07:45 AM
EVO8904's Avatar
I was told that the ralliart T-stat is a waste of money and it will make your car run like sh*t because it make your car's ECU think that the car is not warmed up because it opens up 10 degrees colder than the stock T-stat.
Old Feb 3, 2007 | 09:45 AM
MR 600's Avatar
Originally Posted by EVO8904
it will make your car run like sh*t because it make your car's ECU think that the car is not warmed up.
Can anyone confirm this??
Old Feb 3, 2007 | 11:30 AM
jbrown's Avatar
A radiator is too important to be bought from eBay. An o2 housing or exhaust is one thing, but a radiator??? No thanks.
Id' look at Koyo or PWR, but there are plenty of other things you can do before you need to go there. I have a Ralliart T-Stat, but I am on an AEM EMS, so I have no idea how the stock ECU would respond.
420a-t
Feb 23, 2015 07:19 AM
Viegasjuice
Oct 7, 2014 12:03 AM
Erik…
May 6, 2014 07:35 AM
TheBigD
11
Mar 7, 2014 07:08 AM
Juan Martinez
Lancer Engine Tech
Feb 27, 2009 01:03 PM
