Whats better 1g DSM BOV or Evo 9 BOV?
Old Feb 5, 2007 | 10:02 AM
  #31
EVO8LTW's Avatar
If you have an upper pipe with a 1G flange, the only easy options are the DSM 1G valve, the Forge 1G valve and the Greddy Type S valve. I just ordered the Dejon kit last night.
Old Feb 5, 2007 | 10:20 AM
  #32
kmcconn9's Avatar
Stock IX DV, which is the JDM MR DV. It's an improved version of the old 1G BOV. Buschur used that as the BOV of choice when VIIIs came out, because the VIIIs had plastic BOVs. We didn't get the aluminum JDM MR DV until the IXs were released, but BR's packages were already set.
You would be downgrading if you went with the 1G.
It would be a downgrade with the 1g unless you were utilizing the dejon leak stop kit....
Old Feb 5, 2007 | 10:45 AM
  #33
TeStUdO's Avatar
Originally Posted by EVOfunk
Uncrushed 1g >> 23psi max here.
Are any of you guys having noise issues with this BOV? Mine came as part of the Buschur upic kit. At low-mid speeds, every time I lift the gas pedal it whistles/squeaks quite a bit. It sounds like worn out brake pads...it's driving me crazy! Is there any fix to this problem?
The whistle under vacuum is the bov sucking air in. If you're uncrushed it probably happens around 12-15 inches of vacuum. There isn't really a way to stop it, crushing it will move it up to 18-20 but it will still happen then. Just a "feature" of the bov.
Rich, you dont need to crush the BOV with the kit, it will still work fine. Let me know how you like it after the install
Old Feb 5, 2007 | 12:29 PM
  #34
Danny23's Avatar
Originally Posted by andyboy
i am also running a 1g on uicp and my evo 8 br350 runs like a dream! i got this idea from "danny 23" and put it to work. what an awesome setup !! there is no comparison to other dv's. the stock location always had issues (tried 6 dv valves). i am running @ 21 psi uncrushed. everyone should try this set up, you will love it, no issues at all, thanks again "danny 23".
MY pleasure brother. Glad it worked out for you.
Old Feb 9, 2007 | 11:22 AM
  #35
EVOfunk's Avatar
Thanks for the info. Non-fixable then, that really sucks.
Old Feb 11, 2007 | 05:25 PM
  #36
trinydex's Avatar
http://www.socalevo.net/forum/index.php?topic=37191.0
Old Feb 11, 2007 | 08:08 PM
  #37
MitsuJoe's Avatar
I am confused...was the writeup meant to do it 1G BOV or the EVO9 BOV? Looks good and that is the only good way to make a 1G BOV work as it should.
Old Feb 11, 2007 | 08:11 PM
  #38
kyle424's Avatar
I know its but i would go tial bov
Old Feb 11, 2007 | 08:18 PM
  #39
MitsuJoe's Avatar
Must be nice to have an EMS! You are silly to run the tial/atmospheric BOV without the proper engine mgmt.
Old Feb 11, 2007 | 08:52 PM
  #40
trinydex's Avatar
there's pics for both... the directions are generic but are the original gus mod how to. nowadays you can buy the bov premade from dejontools or drill and tap and use a nipple instead of a rod or whatever he used.
Old Feb 12, 2007 | 05:54 AM
  #41
kjewer1's Avatar
Awesome, nice to see Gus getting the credit for the original Gus-mod. DT copied it, and has gone through a few evolutions on the control system.
I feel like I've posted about this extensively somewhere on this site, but I enjoy this topic for some reason. I run a Gus-modded 1g valve. Holds tight to as high as I can test it. I don't normally run any type of control system on it, but the best system almost invariably works out to be a simple WOT switch based system. Wether you use something DSMlink or AEM to do it, or an actual switch on the TB. For the last couple years with the EVO I've just been pulling the Gus line so it holds at the track, since I NLTS anyway, then put it back on when I leave.
I did the latest version for the EVO with all 1/16th NPT fittings. It's a bit tricky, but the end result is excellent. Nice and clean, strong, and no leaks.
I'm tempted to go back to a Tial now that I'm running the AEM, but I love these backyard engineered parts...
Old Feb 12, 2007 | 12:16 PM
  #42
EVO8LTW's Avatar
I just received my leak stop kit from DT. Do I need to disassemble it and put thread sealant on those fittings, or does DT take care of that for you?
Old Feb 21, 2007 | 09:03 AM
  #43
kmcconn9's Avatar
which fittings? Did you buy the 1g valve from them too with it already modded, or did you just buy the leak stop kit?
If they modded the 1g valve for you then all you have to drill and tap the uicp for the boost source and then tap into your bov line per the instructions and your set...
Congrats on the purchase...you wont be dissapointed with the best bov for stock ecu
Old Mar 11, 2007 | 05:52 PM
  #44
EVO8LTW's Avatar
I decided not to tackle the leak stop install myself, and just sent the kit and my valve to Dejon to do it for me (only $10). They turned it around pretty fast and I installed it today. Haven't done any logs or serious testing, but in the initial drive it seems to maintain all of it's drivability. The only thing I notice different is that when you let off after boost, the release is much more punctuated and rapid. The venting seems to happen faster. I haven't logged boost or anything yet, but so far so good. It certainly looks interesting with all of the hoses.
Old Mar 11, 2007 | 05:55 PM
  #45
EVO8LTW's Avatar
I didn't tap the UICP. Instead, I tee'd off vacuum line from the compressor outlet pipe.
