Installed Boost Control, now problems ??
Old Feb 4, 2007 | 11:55 AM
BoostEEd's Avatar
I purchased a Dejon Tools MBC after hearing it recomended by so many around here. I installed it just as directed in its instructions and per this post here:
http://www.evotuners.net/forums/show...ighlight=dejon
Before the install I would hit 20psi of boost and hold 18-19 just fine. Now I hit 19psi of boost and don't hold sh*t. I am not sure what is going on, but I have tried turning the thumbscrew in and nothing has changed... Any ideas?
I have the tube FROM the vaccum line at the BOV connected to the inlet on the MBC directly opposite the thumbscrew (bottom) and I have the nipple out the side connected directly to the wastegate. I did not use their connector with the hole drilled in it. I capped off the turbo nipple and the one on the intake tube.
Whats going on here? Do I need to use the fitting with the hole drilled in it? I didn't see if used in the writeup? Wuld that really make a difference?
Old Feb 4, 2007 | 11:59 AM
BoostEEd's Avatar
Originally Posted by EVODoesIt
Do I need to use the fitting with the hole drilled in it? I didn't see if used in the writeup? Would that really make a difference?
I see it in the writeup now... I wonder if thats my problem...
Old Feb 4, 2007 | 12:03 PM
BoostEEd's Avatar
hmm reading the isntructions it sounds like it may be. What a dumbass. I'll go install and try again.....
Old Feb 4, 2007 | 12:41 PM
BoostEEd's Avatar
Yup. Dumbass award here!
I will leave this so if anyone makes the same mistake of not following the instructions they can read it and not feel all alone in their stupidity!
