Boost Characteristics of A Large Turbo
Old Feb 8, 2007 | 04:49 AM
  #61
deadbeatrec's Avatar
Originally Posted by boostin'
Originally Posted by browningderek:
1- run a boost line straight from the lower ic pipe to the bottom on the wastegate.
2- put a tee fitting somewhere in that line.
3- run the line off of the tee fitting to the inlet side of your bleed style controller.
4- then run a line from the outlet side of the controller to the top of the wastegate.
^^^^^ this is what i was referring to for you guys
what was the purpose of this?
Old Feb 8, 2007 | 11:52 PM
  #62
boostin''s Avatar
Registered User
If you read browningderek's full post on it he was saying that connecting a mbc of some sort would help i think with holding the boost set all the way to redline. Its a few pages back in this thread. I found it interesting and was wondering if you or Koe tried it that way and liked it or not.
Old Feb 9, 2007 | 04:31 AM
  #63
mine will be installed in one week from today, tuned and installed by professionals. im sure they will know what to do.
Old Feb 9, 2007 | 04:54 AM
  #64
boostin''s Avatar
Registered User
post some pics of it installed afrter youre done with it.particuraly around the wastegate to boost controller. Need a visual on which way to connect my mbc to it soon thanks.
Old Feb 9, 2007 | 04:57 AM
  #65
dude its simple. do u currently have a boost controler hooked up? well hook it up the same way.one goes to the wastegate and the other to the nipple on the LICP or the diverter valve.
Old Feb 9, 2007 | 06:00 AM
  #66
boostin''s Avatar
Registered User
Hey Koevo are you using a 3" tp to connect to your 2.75 dp(atp dp that is)?
Old Feb 9, 2007 | 06:12 AM
  #67
what is a tp and ATP's downpipe is 3"
Old Feb 9, 2007 | 06:20 AM
  #68
scorke's Avatar
TP is toilet paper, or in this case, a test pipe.
Scorke
Old Feb 9, 2007 | 06:35 AM
  #69
Scorke
well the 3" ATP downpips will fit to the stock cat, so in other words almost any "TP"
Old Feb 9, 2007 | 11:29 PM
  #70
boostin''s Avatar
Registered User
^Have you measured your flange then?
Old Feb 9, 2007 | 11:30 PM
  #71
boostin''s Avatar
Registered User
my atp is 3" but at the flange it necks down to a 2.75" flange my concern or curiousity is if the regualr 3" tp's out there will mate up without any leaks between the flanges/gaskets being 2.75 flange to a 3" inlet.
Old Feb 10, 2007 | 05:00 PM
  #72
mine doesnt. hum not sure what to tell u
Old Feb 17, 2007 | 11:37 PM
  #73
boostin''s Avatar
Registered User
so dead how did the tuning on your turbo go?
Old Feb 18, 2007 | 07:05 AM
  #74
the thread is up bro!!!
Old Feb 18, 2007 | 11:34 PM
  #75
boostin''s Avatar
Registered User
^^^ I like your tune bro !!!!!
