What is the highest PSI you can run on a stock evo9 motor?
Old Feb 6, 2007 | 07:06 AM
hacellular's Avatar
At what PSI would be the safes?
race gas (c16) ?
pump gas 93 ?
Old Feb 6, 2007 | 07:12 AM
Ultimate CC's Avatar
there is no safe psi, there are more variables, like what turbo, timing afr's etc...
Old Feb 6, 2007 | 07:24 AM
Curt@MrLed's Avatar
Former Vendor
well he says stock evo 9 motor, so that would be assuming everything is stock, in that case race gas is useless to you..
Old Feb 6, 2007 | 07:52 AM
Top_End_EVO's Avatar
21 psi on stock turbo with a stock block is not the same as 21 psi on GT35R turbo on stock block.
Old Feb 6, 2007 | 07:54 AM
jasonrp15's Avatar
I wouldnt take it past 22psi
Old Feb 6, 2007 | 08:14 AM
Evo9tunerz's Avatar
I run 22psi on pump gas
Old Feb 6, 2007 | 08:20 AM
Warrtalon's Avatar
There is no answer to that question. Please ask a new one.
Old Feb 6, 2007 | 08:22 AM
Nez136's Avatar
On the stock/stock like turbo with headstuds it would still be safe around 28psi or so (as long as your AFR's are good and there is no knock!), with anything larger of a turbo, i wouldn't take it past 25-26psi. Although not a huge risk, there are a lot of people out there running 30 psi or so on the stock block with large turbos but most of them know there is still a risk they are taking. There is always going to be a greater chance of engine failure when running so much power on the stock internals.
PhoenixEvo's Avatar
I am no Warrtalon groupie but that was just tooo damn funny
Old Feb 6, 2007 | 08:24 AM
Pure Playaer's Avatar
without headstuds? id probably say 24 at the most safely..
with headstuds, up to 30
Old Feb 6, 2007 | 08:25 AM
Warrtalon's Avatar
Negatory, ghostrider.
Old Feb 6, 2007 | 08:49 AM
Nez136's Avatar
Is the pattern full?
Old Feb 6, 2007 | 09:15 AM
mathgeek's Avatar
For what it's worth, Al tuned my car to run at 20.5 psi. I don't have a MBC - just a custom tune. And I run 91 octane here in Cali. He assured me that this is a safe level, and I believe him. But I'd be nervous with anything higher.
Old Feb 6, 2007 | 09:23 AM
mcwop23's Avatar
I'm tuned for 23PSI on 93 pump
I've run 26-27 on race gas with no probs thus far
Old Feb 6, 2007 | 09:24 AM
3SgteGuru's Avatar
here is something to think about. Just turn up the boost until your motor blows, then you know how much boost you motor can take.
