Need upgraded Intercooler with uncut undertray?
Old Feb 7, 2007 | 05:45 PM
  #31
the1andonlyE's Avatar
Ams or Buschur Racing
Old Feb 14, 2007 | 12:00 PM
  #32
Candyman's Avatar
Originally Posted by yikez
I posted a thread like this in the general section yesterday.
will the AMS or TURBOXS fit with a Carbing undertray?
someone mentioned that an AMS will fit with a Beatrush undertray i was wonderin if it would fit with a Carbing ......
Just take a look behind the OEM intercooler; on the bottom of the radiator support there are 4 bolt holes. As long as your intercooler doesn't hang father than 1" to 1.5" below those holes, Carbing will work.
If you want to keep your factory chassis brace (3-bolt one), you'll need to cut a 1.5" x 1.5" square out of the carbing panel, 5 min w/ a dremel.
I run Carbing w/ a Perrin FMIC - the Perrin FMIC fits fine w/ the OEM underpanel as well.
Old Feb 14, 2007 | 06:01 PM
  #33
hondafan's Avatar
[QUOTE=Candyman;3977429]
[QUOTE]
can you show me a pic? and what wheel did you use on the dremel?
Old Feb 14, 2007 | 06:02 PM
  #34
555R's Avatar
+2 on the perrin
Old Feb 14, 2007 | 06:04 PM
  #35
joeMama's Avatar
the plastic just gets in the way anyway
Old Feb 15, 2007 | 12:22 AM
  #36
MR 600's Avatar
Thanks for all the feedback guys.
I think i am going to go with the PERRIN.
Old Feb 15, 2007 | 08:17 AM
  #37
Mad_SB's Avatar
Originally Posted by CBRD
actually having more efficient flow under the car aids in air moving through the ic...
its best to keep it.
cb
^+1^
the obx fits without cutting the tray, it is a knockoff of the perrin. It took a little modification of the barcets to get it to fit up clean, but if you have a dremel and some washers handy you should be fine.
Old Feb 15, 2007 | 08:11 PM
  #38
555R's Avatar
Perrin
fits perfect on my IX
its straight as an arrow
bolts up with a slight cut on the plastic side deflection plates
a razor knife and 10 seconds
fits like a glove
Old Feb 20, 2007 | 08:08 AM
  #39
Candyman's Avatar
Just a regular old cutting disc. I attached a pic.
Attached Thumbnails Need upgraded Intercooler with uncut undertray?-carbing_4.jpg
Old Feb 20, 2007 | 08:09 AM
  #40
Candyman's Avatar
Originally Posted by 555R
Perrin
fits like a glove
Amen - fits perfectly and it's big.
Old Feb 20, 2007 | 08:32 AM
  #41
Candyman's Avatar
Here's another shot of the Carbing mounting bracket.
Old Feb 20, 2007 | 08:53 AM
  #42
Aby@MIL.SPEC's Avatar
the spearco fmic fits great with the oem undertray & has tabs to put the oem plastic PITA fastners through the undertray into the fmic
Old Feb 20, 2007 | 03:30 PM
  #43
AirNKAir5's Avatar
i recommend buschur, it fits perfect and was an easy install.
Old May 22, 2007 | 06:17 AM
  #44
Bosshog's Avatar
old thread, but I want to confirm that APS intercooler fits perfectly without cutting the stock undertray. no trimming of any kind required and it fits the pipes perfectly as well..
Old May 22, 2007 | 10:37 AM
  #45
shivaswrath's Avatar
ETS intercooler, special going on it right now. . .no cutting and no pressure drop. . .
lbcevo
Sep 18, 2011 10:18 PM
pupo
38
May 18, 2009 03:27 PM
whitenblue65
13
Aug 6, 2008 10:30 AM
RevMoto
Apr 10, 2008 10:33 AM
bpclements
Oct 6, 2004 11:42 PM
