Boost problem
Old Feb 6, 2007 | 10:22 AM
LuisIX's Avatar
Boost problem
well i finally recieved my stewart warner boost guage and i come to find out im only spiking to 17psi then tapering off to 15 then 13 by redline.ive searched around and came to the conclusion that stock boost is supposed to be 20.8psi correct me if im wrong.
What bothers me is the car is stock i had an aftermarket intake on the car and figured that was the problem so i removed it put the stocker back in this morning and the same thing is still happening after i took it for a drive.so i know its not the intake.the next thing i could think about is testing for boost leaks.i gonna be doing this within the next hour or so.please chime in as im running out of possibilities.what else can cause this type of problem.
the car is new why would it have a boost leak the only thing i messed with is the vaccum line from the Diverter valve for the guage and i have that thing all ziptied up.
also if the car had a boost leak wouldnt my idle be all screwed up?my car idles perfect bythe way.
Old Feb 6, 2007 | 11:57 AM
LuisIX's Avatar
well i did the boost leak test didnt find nothing .car held 25 psi n the system.
so know what do i do.
should i just get a mbc and set it to 21 psi.
Old Feb 6, 2007 | 11:58 AM
LuisIX's Avatar
Old Feb 6, 2007 | 12:26 PM
LuisIX's Avatar
i went ahead and bought a boost controller.**** it im gonna squeze 21 pounds out this b****
Old Feb 6, 2007 | 12:38 PM
Evoryder's Avatar
...handle the issue all by yourself.
Old Feb 19, 2007 | 09:03 AM
Ralph's Avatar
Make sure you run a datalog after you start cranking up the boost.
Who knows, maybe your "17psi" was actually 20psi and the gauge is off. Now you'll be at 23 :O.
Datalog the ***** to be sure .
Tactrix Cable $90
MitsuLogger FREE
Old Feb 19, 2007 | 09:30 AM
deadbeatrec's Avatar
Tactrix Cable $90
MitsuLogger FREE
u do realize that not everyone has a laptop. if i were u i would see if a friend has a boost gage and make sure they are reading the same. then go from there.
Old Feb 19, 2007 | 01:05 PM
Jersey Dino's Avatar
what kind of gas are you running? I know california has low octane gas, 91 is the highest octane right? do the cars acheive a full 20psi on this gas?
Old Feb 19, 2007 | 01:51 PM
Evo_Jay's Avatar
A lot of the later IXs never hit target boost from the factory.
Old Feb 21, 2007 | 07:13 AM
LuisIX's Avatar
hey ralph i might have to call you up so you can show me how to do this.does the tactrix caple plug right up to our ecu.enlighten me ive never been to familiar with mitsubishi ecu's.
Old Feb 21, 2007 | 07:18 AM
alan678's Avatar
I had a similar problem with my auto meter gauge....i purchased the innovate motorsports LMA-3 MAP sensor here recently and my "21lbs" on the boost gauge was really "18lbs" according to the MAP sensor....might want to invest in one...
Old Feb 21, 2007 | 07:21 AM
alan678's Avatar
I achieve 23lbs all the time...its all about the tune....23lbs and no knock...
Old Feb 21, 2007 | 02:26 PM
Evo_Jay's Avatar
Alot of analog gauges are off, just like yours.
Lesson - Always use a MAP sensor for boost claims
Old Feb 21, 2007 | 03:31 PM
GgreyEVOIX's Avatar
I have the same issue, bro it's normal.
My peak boost is 18 psi tappering down to 14-15 psi. My friend did a boost leak test last week and found nothing wrong. My car still makes power so I just assume it's normal.
Old Feb 21, 2007 | 03:35 PM
joedr's Avatar
EvoM Moderator
Shoot... I have an MBC and my car spikes at 25 and is down to 18-17 at redline (7800).
No knocks and 11.5 AFRs @ 3rd gear. I used a med grade map sensor inside the car to log the boost.
