BOV issue...causing car to die..
Old Feb 6, 2007 | 04:32 PM
Evo4Ash@D's Avatar
i have a 03 evo, i just put a turbosmart evo specific bov on it not(not the universal one) love it , it sounds great, but when i boost and then let off the gas or sometimes just putting around in general the car will idle down really low and sometimes die, ive loosened the spring tightened it, im just kinda like blah right now...any help would be great thanks...
Old Feb 6, 2007 | 04:34 PM
Curt@MrLed's Avatar
Former Vendor
is it recirc. back into the intake.. i hope it is..
Old Feb 6, 2007 | 04:47 PM
Evo4Ash@D's Avatar
yes its a recirc...bolts in as factory as well..
Old Feb 6, 2007 | 04:59 PM
steevo's Avatar
Are you sure you didn't get the Turbosmart Dual-Port bov? That's the only Evo specific one I've seen. That valve will always VTA some....causing your problem.
davidpath's Avatar
you no i had the same problem on mines but i had the hks ssqv...an it would do the same...but i had my ecu flash and tune...it didnt cuz that anymore...
Old Feb 6, 2007 | 05:09 PM
Evo4Ash@D's Avatar
then i wonder why they would make them if they know there gona do that, so in the case as below me will a flash and tune fix some of my problem...
Old Feb 6, 2007 | 08:13 PM
steevo's Avatar
No a tune won't fix your problem with the bov. It should have came with a recirculation plate. Use it, or put back on your stocker.
Old Feb 6, 2007 | 08:32 PM
Evo4Ash@D's Avatar
it came with a plate....hte directions say optional for blocking supersonic port. so if i use this plate will it make it a non recirculating,
Old Feb 6, 2007 | 08:42 PM
hopper's Avatar
I admit i don't really deal with turbosmart very much. But im assuming that the plate you are reffering to is the recirculation plate. I would install it.
Old Feb 6, 2007 | 09:24 PM
ninja808's Avatar
HKS makes an Idle stabilizer, or you can get a MAF Stabilizer both sold at Lancershop. This will trick your car into thinking the recirculation is still hooked up.
Old Feb 6, 2007 | 09:51 PM
Evo4Ash@D's Avatar
hmm...i cant seem to find it on lancer shop, put up a link if you will..
Old Feb 6, 2007 | 11:10 PM
Warrtalon's Avatar
No, no you don't use the HKS EIDS for this - don't even bother.
Old Feb 6, 2007 | 11:22 PM
EVO8URV8's Avatar
Stock IX or JDM MR BOV >>> *
Old Feb 7, 2007 | 08:11 AM
Tuner@Swift's Avatar
Dude, the blocking plate replaces the "bell" shaped piece on the BOV, not the part that goes back into the intake side. Once you block that port off, it will recirculate 100%. Also, make sure the BOV is in correctly and not backwards, a lot of times people will install this BOV wrong.
Old Feb 7, 2007 | 08:31 AM
schred86's Avatar
stiffen up the spring if it is adjustable, i had that problem w/ my greddy rs and that fixed the problem.
