Just got a Carbonetics twin carbon installed and it sounds bad
Im not really worried about the money, I was just worried about the noise. Now that I know its not going to kill anything , then Im fine. Other then the noise, it really did add to the pick up. Could it be possible that this clutch added a little WHP? Im almost sure it did.
hey guys, just to provide some clarification here:
03/04 Evos: No ACD = chatters while clutch pedal is engaged, but decel noise is going to be noticeable coming from the TC.
05/06 Evos: With ACD = the decel noise shouldn't be there, but it still chatters while clutch pedal is engaged.
Hope this is useful...
mike @ Mynes
mike @ Mynes
Our Shop 8 (04 model) had an ACT and Exedy Twin before, and both did not last more than a few months - it now has the Carbonetic Triple Carbon on it. Since it doesn't have an ACD, the decel chatter is quite loud.
Like someone else mentioned on here, any time you have free floating disc, there's bound to be some noise.
BTW, what's the going rate for the Exedy Triple?
o man, last night there was a thread of the carbonetic twin plate clutch, this guy had it on his evo and was going through some problems w/ the clutch, found out after big problems w/ shifting, the plate cracked in half.
i had this clutch and it was very annoying, probably the loudest twin I have heard. The guy at the track thought my car was broken and wouldn't let me run. My Exedy Triple is quiet and I have also used the twin quartermaster and that was even not that loud.
wow its that loud he wouldnt let you run. im thinking about this clutch myself and gettin rid of the exedy triple metallic. but still not sure??????
i have this clutch and when the clutch is depressed it chatters....also when you let off gas it chatters also....i got used to the noise though....it isnt that annoying as people make it up to be....come on people you drive evo's they are not supposed to be quiet.
btw, if you dont like the chatter dont ever get aftermarket mounts......you will hate your car even more with this clutch and mounts.
mike @ Mynes
mike @ Mynes
the WHP your feeling is probably from what you were losing due to your old clutch slipping. now that you have this new strong clutch that isnt slipping thats the WHP your feeling. thats my guess.
