Oil/fuel press. gauge install
Old Feb 10, 2005 | 08:35 PM
evo8dad's Avatar
Originally Posted by Kyperion
This is perhaps the most misguided advice I have seen in a long time. The idiot light that the evo does have is really not going to save your turbo bushings in the event of a sudden oil pressure drop at High RPM (cause it does ntoe come on until the oil pressure is too low to give you time to properly shutdown. An oil pressure gauge is vital to monitoring and safeguarding the engine in any high performance car, especially one as high strung as the Evo.
Thank you
For those of you interested, I have found several good spots for an oil pressure gauge to read off of. The first and most obvious spot is the stock oil pressure sensor. Although that sounds easy enough, it is a REAL ***** to get to. There are several ways to get to it. The easiest is if you are installing a clutch because the sensor is right above the transfer case and once that is out of the way it makes it a snap to get to. The other way is taking out pretty much everything near the master cylinder side of the engine bay and the majority of the stuff around the throttle body. The other location would be to T into the oil supply line for the turbo, although this would monitor only the pressure going to the turbo (well it would also give a pretty good indication if something is up elsewhere to).
By the way, for some stupid reason Mitsu engineers decided to use British pipe tread rather than National Pipe Thread on the head and block just to make things that much more difficult.
