Rough idle
Old Feb 8, 2007 | 08:28 PM
STOCK_EVOLUTION's Avatar
Question Rough idle
serached but didnt seem to find "my" problem...
every morning or when i start my car after it has been sitting for a while the rpm's keep going from 500rpm's to 1,000 rpm's.. the car kinda shakes a little this goes on till the car is warmed up or till i give it some gas.. the wierd thing is that this only happens when the heater is on or the a/c...
Old Feb 8, 2007 | 08:36 PM
evo150's Avatar
you can check for vaccum leaks, but when the heat or vents are set to defrost, the ac is on or you have the rear window defrost on it does this. how is the idle after the car is warmed up and the ac is off, vents are set to floor/dash?
Old Feb 8, 2007 | 08:41 PM
Rom's Avatar
Rom
Um, an 05 VIII? Isn't it still under warranty?
S.
Rom's Avatar
Rom
Oh, wait, you modified it... They probably won't warranty it - unless you remove the mods!
S.
Old Feb 8, 2007 | 09:53 PM
ninja808's Avatar
Sounds like you may be experiencing an issue with one of your O2 sensors faulting.
Old Feb 9, 2007 | 12:01 PM
Rom's Avatar
Rom
I doubt it's an O2 sensor since the ECU would run open-loop before the engine warms up (and thus pretty much ignore the O2 sensor since it takes a little while for it to reach operating temperature).
I think the best bet would be to check for a vacuum leak first. The A/C doesn't really affect the engine except as an additional load, which could potentially aggravate a problem. The heater (without A/C) is a bit puzzling though. That's pretty much just a fan (blowing through a water-to-air heat exchanger). It does present an additional electrical load on the system, but I wouldn't think it would affect things so greatly - unless maybe you have a faulty ground somewhere. That's something else to check.
Thanks, and good luck!
S.
Old Feb 9, 2007 | 12:05 PM
Warrtalon's Avatar
His mod list answers the question!
rorymouse
Dec 13, 2013 12:03 AM
mitsuevodriver
14
Mar 6, 2010 10:16 AM
spooln2004
15
Mar 9, 2009 04:59 AM
strongbear0
15
Apr 12, 2005 11:02 PM
DynoKing
Dec 27, 2003 04:41 PM
