23psi stock EVo...
Old Feb 10, 2007 | 09:25 AM
Soon2BEVO's Avatar
Originally Posted by saiyanzzrage
not at all, i would recommend 28psi, and a vta bov to go along with it too
Old Feb 10, 2007 | 10:47 AM
TurboIX's Avatar
Originally Posted by Rnm
I wouldn't raise the boost if I still had the stock exhaust.
Why do you say that?
Old Feb 10, 2007 | 11:15 AM
Nad1370's Avatar
If your optimally tuned for a certain psi, then you should stick with that. Some cars felt slower when boost is raised.
If you plan to raise it, then raise your octane aslo to combat knock.
Must have some type of logging device for knock, a/f, timing, ect...to ensure your making more power and not losing it.
Stock IX pump should be fine for basic mods.
Old Feb 10, 2007 | 12:20 PM
sparky's Avatar
Originally Posted by EVOIXMR8916
pump in any stock ix is a 255lph which flows just as much fuel as walbro....
I think that the stock IX pump is good for about 230 LPH. Maybe hotwired(higher voltage) it could keep up with the Walbro 340. I donīt know though. If he's gonna be running over 26 psi, the WALBRO is cheap insurance. An AFR gauge would be a good addition as well.
Old Feb 10, 2007 | 01:06 PM
GgreyEVOIX's Avatar
you really want 3 extra psi? what 20 isn't enough already?
Old Feb 10, 2007 | 06:14 PM
HOSrt4's Avatar
yeah just to be safe id get the walbro
Old Feb 10, 2007 | 06:45 PM
whitey4d's Avatar
Originally Posted by SilverNine
I know right? I feal that way talking to 90 % of the people in here. Also Al has a case study abput why he thinks even IX owners should get a Walbro. Search and you will find it.
Old Feb 10, 2007 | 06:48 PM
whitey4d's Avatar
Is there any real need to hard wire a pump in an EVO? I mean there already is a twin circuit system for higher voltage built into the car already. The DSMs were a whole nother story. It was mandatory in them.
Old May 26, 2007 | 07:51 PM
evoballer's Avatar
Im running 23 psi and i have the stock exhaust, arc intake , and a aem wideband and the a/f ratio is fine not to lean but im still buying a Safc-neo soon. I have not had any knocking.
