23psi stock EVo...
Old Feb 9, 2007 | 09:32 PM
TurboIX's Avatar
23psi stock EVo...
would raising the boost to 23psi on a basically stock EVo a bad idiea?..even with 96octane?
Old Feb 9, 2007 | 09:43 PM
chaotichoax's Avatar
my car was tuned to spike at 24 and hold 22.5 and runs very well
23 is about as high as you want to go on pump gas and it definitely would be recommended to be tuned to make sure your afr's are okay and you aren't knocking
Old Feb 9, 2007 | 09:45 PM
CRX2EVO's Avatar
fuel pump
Old Feb 9, 2007 | 09:46 PM
TurboIX's Avatar
Well I have no mods but AL did tune my stock EVo for a little over 21psi..I was thinking of maybe just uping the boost to 23psi for the track and run race gas/pump gas mix.
Old Feb 9, 2007 | 10:18 PM
mcwop23's Avatar
Originally Posted by CRX2EVO
fuel pump
unnecessary on a IX with basic mods
Old Feb 10, 2007 | 07:22 AM
gsrboi80's Avatar
I would not chance that at all espescially at 23lbs+
Old Feb 10, 2007 | 07:24 AM
saiyanzzrage's Avatar
not at all, i would recommend 28psi, and a vta bov to go along with it too
Old Feb 10, 2007 | 07:25 AM
EVOIXMR8916's Avatar
pump in any stock ix is a 255lph which flows just as much fuel as walbro....
Old Feb 10, 2007 | 07:33 AM
Muad's Avatar
Your fuel is what determines how much boost you can run. I learned this beasue I asked David B. when he and AL flashed my ecu, "what psi am I tuned for?". He said you don't tune for a specific psi, if I remember right. with 93-94, he told me to run 21-22psi. with C16, 25-26psi. I am stage 4+, running FP's "White Rabbit".
So, if you are running some sort of race gas, I don't see why you couldn't up the boost. If I am wrong, please someone correct me. Hope this helps.
Old Feb 10, 2007 | 07:44 AM
EVOBrad's Avatar
Are you sure that's accurate? Everything I've read indicates that the Walbro is superior even on an IX.
Old Feb 10, 2007 | 08:19 AM
HOSrt4's Avatar
I dont think that the ix has a 255 in it, i also heard it is a little bigger then the viii but not as big as a 255.
Old Feb 10, 2007 | 08:22 AM
SilverNine's Avatar
WHAT?!? no... All tuners recomend u get an upgraded fuel pump when raising boost....its recomended and for 75bux its worth it....
Old Feb 10, 2007 | 08:31 AM
SilverNine's Avatar
Old Feb 10, 2007 | 08:39 AM
Rnm's Avatar
Rnm
I wouldn't raise the boost if I still had the stock exhaust.
Old Feb 10, 2007 | 09:02 AM
thebluesky's Avatar
I'd love to see where you read that one. THe IX does have a better fuel pump than the VIII stock, but it is NOT a 255 lph.
