Boost gauge tap in point
Old Feb 11, 2007, 12:13 PM
asasin79's Avatar
i put a T in the rubber line on the back driverside of the valve cover directly between the 2 hard lines. those hard lines go to the bov.
Old Feb 11, 2007, 07:45 PM
JohnEB's Avatar
Sorry so long, long day at work
Anyways here are two pics for you guys of where my boost gauge line is tee'd in. This is what I think is the ideal to tee a boost gauge line in so you don't have to take the risk of going into the fpr line and having that pop off causing potential harm to your motor.
Old Feb 11, 2007, 08:07 PM
boostless's Avatar
Originally Posted by ak47po
QUOTE
TECH TIP: It is ideal to connect to a vacuum hose that goes directly to the intake manifold whenever a vacuum/pressure source is needed. Some hoses connected to solenoids or the throttle body may not read pressure all the time (or at all) and some may not read vacuum. Using any hoses with those characteristics will obviously give you very inaccurate readings...or none at all. The particular hose from the fuel pressure regulator to the bottom of the FPR solenoid reads vacuum and boost 24/7, so it's a prime candidate.
Tie strap all vacuum lines at their connections to ensure they will not blow off under boost.
After your connections are made to the gauge or Control Unit II, start the car and check that the gauge is reading vacuum. Stock Evos will read approximately 16in/Hg (.55 BAR).
This is the most common way to do this install. I'm perfectly comfortable because: 1. I have NEVER heard of the hose blowing off... 2. It's Mitsubishi's method. If it were a real concern, those would be exact opposites.
Old Feb 11, 2007, 08:09 PM
JohnEB's Avatar
I am sure it will work but this is just in a way a fail safe method...... I do believe there are people that have had them pop off that I have seen on here but either way it works as long as you are safe about it and use at least zip ties.
Old Feb 12, 2007, 12:14 AM
ninja808's Avatar
Mine is tied in with the fpr, and it has popped off after upping the boost a bit, but I ended up putting two zipties on it and all has been good.
Old Feb 12, 2007, 05:15 PM
JohnEB's Avatar
^Lucky^
Old Feb 12, 2007, 05:27 PM
nothere's Avatar
I can assure you the tee in the location pictured above will work perfectly, 24/7/365.25 (johneb's pic)
Old Feb 12, 2007, 05:52 PM
JohnEB's Avatar
Has worked perfect for me!
Old Feb 26, 2007, 03:45 PM
LIL EVOL's Avatar
Any more feedback? Has anyone else t-d their boost line here? I have and my boost is about 2psi low and seems to hesitate registering slightly when coming on. Power comes on just fine. I have a new Autometer gauge on the way to confirm. No leaks either. Jusst checking, I guess Autometer gauges can be inaccurate sometimes.
Old Feb 26, 2007, 03:58 PM
NoTec's Avatar
Defi BF here and tapped at FPR like the instructions say. I got it Ziptied down on every conection. The one on the defi sending unit, the one on the FPR, all 3 sides of the T and the one connected to module on manifold. Used the Ziptie gun so I know its tight. Boost is stable as ever and goes from 20 psi to 15 psi like its supposed to.
Old Feb 26, 2007, 04:01 PM
NoTec's Avatar
And Im certain that who ever had a line pop off under boost did not zip tie or clamp it down. I'm not using the little tiny ones either, using the the medium size 8 inchers.
Old Feb 27, 2007, 05:55 AM
LIL EVOL's Avatar
Cool. Anyone else?
Old Feb 27, 2007, 06:07 AM
okevolutionVIII's Avatar
Didnt read the whole thread, but the stock ecu has a run-lean protection. The FPR hose was blown off my car for a while and I didnt know it, but it ran fine.
Old Dec 6, 2007, 03:26 PM
jhanksevo's Avatar
bringing back from the dead I had a bad boost gauge needle shaking problem. My friend suggested I switch from the BOV line to FPR line and the needle shaking went away. I have Defi BFs and they are pretty accurate
Old Dec 6, 2007, 05:46 PM
evolved83's Avatar
hooked mine up to the fpr line and no problems here! just make sure you tie them down
Quick Reply: Boost gauge tap in point
