Well Dave maxed out my turbo...
Old Feb 12, 2007 | 03:40 PM
  #31
Knightracer's Avatar
Originally Posted by dafunk630
step your game up with that 55r
That might be a little small for what I want.
Old Feb 12, 2007 | 03:46 PM
  #32
bolio's Avatar
^Dave has also said he doesn't like the 2.3 and it's only good for making a big turbo Evo streetable. 2.3 traps don't translate to 2.0 high reving drag cars. For an every day street car I love the 2.3 though.
Old Feb 12, 2007 | 04:58 PM
  #33
It'll do good enough tho.
Old Feb 12, 2007 | 06:28 PM
  #34
syktek's Avatar
what software/engine management is this running on? didn't see you list it in your mods, thanks.
Old Feb 12, 2007 | 06:38 PM
  #35
Frenchy4g63's Avatar
Originally Posted by 03whitegsr
I'm confused.
The "GT37R" is a ball bearing P-trim/T67. The T67 is a 75 pound/min wheel and the P-trim has been proven to make 700+ WHP.
The GT4088R is a 68 pound/min compressor wheel.
Why do you guys think the "GT37R" is going to be maxed out before the GT4088R?
A GT4088R's compressor wheel is larger than 68 lb/min. A GT35R has a 65 lb/min wheel. I believe the GT4088R has a 75 lb/min wheel just like the "37R" The difference is that with the larger housing it is more efficient at higher boost levels. Not to mention it is also a twin scroll housing, and pairing that with a twin scroll/divided manifold will help spool the GT40R about the same, if not quicker than even a GT35R w/ .82 a/r housing. The more efficient housing is what makes the GT40R capable of more power than a "37R"
If someone can correct me on the GT4088R lb/min rating, please do. I'm almost positive it is 75 lb/min however.
Either way, I am sure it's larger than 68 lb/min..
Old Feb 12, 2007 | 07:21 PM
  #36
Invoice EVO's Avatar
Veteran: Air Force
AEM EMS
Old Feb 13, 2007 | 12:43 PM
  #37
http://www.turbobygarrett.com/turbob...40/GT4088R.htm
This is what you need to look at.
Old Feb 13, 2007 | 12:58 PM
  #38
Evo8yurAMG's Avatar
well your car is sick...but time to step it up to something bigger...hmmm...i say a 42R or 45...but im sure you can get more HP out of that car...if not then oh well time to buy the AMS stroker that revs
https://www.evolutionm.net/forums/sh...ht=ams+stroker
unless of course you are a one shop buyer...then tell Dave to make a higher reving stroker.
but then again im not sure what kind of stroker you got going on already
Old Feb 13, 2007 | 02:24 PM
  #39
Thanks.I have the AMS stroker kit, and I rev it to 8500-9000 rpm. 45R is too big for my needs.
