Can you Warp the flywheel beond repair?
Old Feb 17, 2007 | 04:08 PM
Turbo Kyle's Avatar
I was wondering if you can really warp the flywheel so bad you cant fix it? The reason I am asking this is because I am about to have my new clutch installed and I smoked my stock one. It got so bad the clutch would slip and would not grap till like 6 grand and I know it was getting hot. If the chances are good it dammaged beond repair I will just get a new one.
Old Feb 17, 2007 | 04:11 PM
Spaceball 1's Avatar
There is only so much material that can be removed and still have the flywheel be usable so yes you could
But i highly doubt that you have done that on a 06
Old Feb 17, 2007 | 04:37 PM
Turbo Kyle's Avatar
Cool I just wanted to make sure. Im sure its pretty blue from heat, but the machine shop will take care of it.
Old Feb 17, 2007 | 04:41 PM
grubiaco's Avatar
You definately can warp it beyond repair. If anything, try to get a new one (if financially feasible) the reason being is because they are down there in the first place. Might as well take care of everything (flywheel, pressureplate, clutch, TOB).
Old Feb 17, 2007 | 04:50 PM
Turbo Kyle's Avatar
Yea, that does make sense. Should I just get a new OEM one?
Old Feb 17, 2007 | 06:46 PM
t51splbb's Avatar
You can get a new one or a lightened one like the Gruppe S, ACT or similiar. If going to an aftermarket one I would at get one of those I mentioned above or similiar because they can be resurfaced if need be like the OEM one. The aluminum ones can't be resurfaced and you have to buy a separate friction surface if it needs replacing which is not always convienient.
Old Feb 17, 2007 | 07:00 PM
Turbo Kyle's Avatar
I will be at the shop helping when they pull the tranny. So I guess we will see what the flywheel looks like and then Ill post a pic on here. I dont want to throw out more $ if its not needed.
Old Feb 17, 2007 | 07:56 PM
kjewer1's Avatar
Slipping till 6k is further than I've taken any clutch/flywheel, so this is a bit out of my range of personal experiences. But one other thing to be careful of is any weakening of the material that may have occured from the excessive heat and heat cycling in this case. I'm no metalurgist, but if you've ever seen the aftermath of a blown up cast flywheel, you'd agree that it's at least worthy of mention. If the machinist that resurfaces it is capable of checking for microscopic or sub-surface cracks I would have that done for some peace of mind perhaps.
Old Feb 18, 2007 | 06:50 AM
EVOllie's Avatar
you definitly can mess it up beyond repair. once you or the shop take it out the should be able to tell (should, if its bad)
But there is a possibility of it looking ok. When you take it to a machine shop to get resurfaced, they'll be able to tell because they can only take off so much. they got the gauges and tools to tell you if its beyond repair.
My car recently buirned up my second single disk, I KNOW there is no way that flywheel is still good. i drag race it, i seized it, over heated it in traffic. So i bought a used one, which i found on this forum. It had 20k miles on it, and owner took it out after he buried up the first stock clutch. It looked good and i had that one resurfaced.
i payed 60 bucks shipped for that used one.
Old Feb 18, 2007 | 06:58 AM
EVOllie's Avatar
haha never seen cast one blow up. u should post some pics or something.
i have seen springs pop out, pads fly off, and once, 2 flywheel bolts worked there way out and get lock between the flywheel and clutch, that was no fun. All these things have happened to me in my old cars.
Old Feb 18, 2007 | 09:22 AM
Turbo Kyle's Avatar
Thanks for the Info
Old Feb 18, 2007 | 03:55 PM
ACTman's Avatar
The EVO flywheel is not a grey iron casting so it is not likely to blow up like most flywheels can. Here is a couple photos of a blown up DSM flywheel (that is grey iron). Of course the damage to the trans and the rest of the car was significant. The stock EVO flywheel is much safer by comparison, but it is pretty thin to begin with so it tends to warp more than I care for. One reason for the warpage is the fact that it isn't grey iron casting. If it were grey iron it wouldn't tend to warp as easy... instead it would have tendancy to crack and blow up. Yeah, I think I perfer warpage over breakage too.\
BTW: Check out how deep the crack is on the last photo. The depth of the crack can be clearly seen by the dark portion that is nearly half way through.
Attached Thumbnails Can you Warp the flywheel beond repair?-flyboom1.jpg   Can you Warp the flywheel beond repair?-flyboom2.jpg   Can you Warp the flywheel beond repair?-flyboom3.jpg
Old Feb 18, 2007 | 04:09 PM
DRFTKNGG's Avatar
^^^^^Yikes...that could take a foot off instantly! Thank god I am installing my scatter shield...dont want any carbon fiber cutting through my firewall!
Old Feb 18, 2007 | 04:10 PM
hk2ronin's Avatar
I just had my clutch done and they almost couldn't resurface the flywheel. I was lucky that they did because I didnt have a stock one laying around. I guess next time I do a clutch I'll get a new stocker to put in because I doubt my origanal stocker will be able to be reused again. Ive heard that some aftermarket ones create vibrations that set off the check engine light. You also want to get a one piece like the fidanza or exedy because the two piec units have a tendacy to come apart which can't be a good thing.
Old Feb 18, 2007 | 05:25 PM
Turbo Kyle's Avatar
I was going to get a one piece flywheel. I was looking at a steel one NOT aluminum. ACTman, What street flywheel would you reccomend? I was lookin at the XACT flywheels
