Perrin 3" hfc v/s Helix 3" hfc
I was looking at the Perrin unit and it seems that is has an O2 bung on the cat portion of the exhaust. (I have retained the stock mid pipe on my 2.5" tbe).
What do I do with the extra bung hole (plug it up with a bolt). Does it come with a bolt?
And there seems to be a price diff. of about $100 b/n the Helix and Perrin. Are they both a "direct replacement" cat (fit stock flanges). Thanks in advance. The search feature is beyond disfunctional.
I have a 2.5" UR HFC (ceramic) right now. I do want to replace it with a metalic substrate cat. The Helix and Perrin are both metallic substrate cats but the Perrin seems to have one too many bung holes for me (where I have the stock mid pipe section with its bung hole). They are both 3" and I believe they are both direct replacement cats. Can anyone confirm this and what do I do with the extra bung hole? 1-2 whp diff. among the cats (if this is the case) in negligible so I'd rather save the $100 bucks. I'm already using the cel fix with my UR cat. I get the CEL every 1,000 or so miles. This is probably indicative of my cat being shot.
Kind of a wierd Q but.
So Im waiting for my evo2 catback to come which is 3 inch. How does that work with the stock cat because isn't it a 2.5? Dunno if I need a different hfc or tp that is 3 inch. Then how does that bolt up to the stock dp? lol. Then if I also get a 3 inch dp how does that bolt up to the o2? Anyone know? Thanks
I have the Perring HFC with about 700 miles so far no CEL. I ended up flipping the pipe 180 and using the extra bung for my wide band. This setup is great the bung sits at about 10 o'clock a couple of inches away from the dp flange when the hfc is flipped. The extra bung is for the EVO 9 rear O2 sensor. It comes with a plug bolt.
Gruppe-S, but most everyone is sold out. Check with them to find out if they expect Helix to continue production this spring.
I picked mine up from an EvoM member, that might be your best bet.
FS[Mid-Atlantic]: Helix HFC (high flow converter)
EVO8LTW
Nov 27, 2016 12:30 PM
stock_evoIX
Jan 31, 2016 06:40 AM
CleverUserName
Jun 1, 2007 08:14 PM
