o2 simulator
Old Feb 21, 2007 | 12:15 PM
l2r99gst's Avatar
FYI, there is a lot of disassembly going on with the stock ECU and one person has already patched his ECU to eliminate the rear O2 cel.
I'm in the process of working this out with my ECU, but I thought that I would throw this out as an eventual option. A simple flash may be all that will be needed.
Eric
Old Feb 21, 2007 | 01:24 PM
GGBaller's Avatar
Just get the 02 fix from Autozone
Old Mar 9, 2007 | 07:45 AM
mitsuorder's Avatar
Eric
Please enlighten me to this "patch" as I have a friend's car that is being quite problematic.
Old Mar 9, 2007 | 08:44 AM
l2r99gst's Avatar
The thread is on aktivematrix dot com under the ECU disassembly section.
Eric
Old Mar 9, 2007 | 08:59 AM
mchuang's Avatar
Go on ebay search for o2 simulators, I got one for 20 bucks, they all do the same thing alter the voltage that the ecu sees pretty much.
Old Mar 29, 2007 | 10:50 PM
apevo8's Avatar
i just got this and intalled it last week, since sunday to just 15 mins it working fine, until i was on the high way and the car started to rumble like it was a boost leak and then it started working fine, but the SES light came on, check the simulator the light is still blinking, what should i do?? reset the battery....also, very interested in that patch...
