o2 simulator
Old Feb 20, 2007 | 12:49 PM
apevo8's Avatar
o2 simulator
hey guys, anyone who knows please provide some feedback, which o2 simulator works the best, the perrin or buschar one, or if there any others let me know, thanks
Old Feb 20, 2007 | 12:51 PM
deadbeatrec's Avatar
learn how to spell his name, and i think they are the same.
Old Feb 20, 2007 | 12:55 PM
AF-Evo8's Avatar
spark plug de-fouler
search for the spark plug de-fouler mod it worked for me 5k+ miles and still no CEL.
AfireINSIDE's Avatar
The $5.00 anti fouler works
Old Feb 20, 2007 | 12:56 PM
AF-Evo8's Avatar
you can't go wrong with a $5-$6 mod that works.
Old Feb 20, 2007 | 01:01 PM
apevo8's Avatar
ya, already got that, doesnt work for me
Old Feb 20, 2007 | 01:04 PM
cpoevo's Avatar
Did you use 2 of them together or just one? I used 2 together and have had no problems at all.
Old Feb 20, 2007 | 01:06 PM
AF-Evo8's Avatar
use 2 of them and drill one out to 1/2" on the inside and put the drilled one on th outside and the o2 screws into that, that work for me.
Old Feb 20, 2007 | 01:27 PM
joeMama's Avatar
i use a perrin O2 simulator, works very well
Old Feb 20, 2007 | 01:28 PM
whitersevo's Avatar
ebay anti-foulers
Old Feb 20, 2007 | 01:38 PM
OZrallyracer's Avatar
Problem some people have with the anti fouler mod is that if you have an aftermarket cat back exhaust system and the bung for the o2 sensor points directly parallel with the under side of the car, the anti-fouler pushes out the o2 sensor right under the underside of the car, past the driveshaft tunnel where it is supposed to rest, and if you were to hit a bump or make the exhaust move in a way that would push the exhaust up higher in the driveshaft tunnel at all, the o2 sensor would break on the underside of the car and then you are f**k'd and need a new o2 sensor. (I never had mine break but when i installed the mechanical cel fix from roadrace i noticed this right away.
Old Feb 20, 2007 | 03:25 PM
AirNKAir5's Avatar
i have the buchur o2 sim and it works just fine...took me about 30 min to install which includes splicing and then putting everythng back together.
Old Feb 20, 2007 | 08:58 PM
apevo8's Avatar
ya, i used 2 also but it still goes on, im just gonna get the o2 simulator cuz of sick of reseting the battery over and over again, o2 simulator it is!
Old Feb 20, 2007 | 09:02 PM
dubbleugly01's Avatar
anti foulers didn't work for me either. Some cars just aren't that lucky. but the electronic 02 sims, they're all basically the same. I'm running the Perrin, works flawlessly.
Old Feb 21, 2007 | 11:02 AM
apevo8's Avatar
sweet, im gonna order that up then
