Question abot HKS Carbon TI Exhaust
Old Feb 21, 2007 | 11:38 PM
MiamiEvo8's Avatar
I will try and post pictures soon. I just bought this exhaust and it sounds great. Only question about it is that it sits against the right side of the bumper. Is this normal or can it be adjusted? If so how? Any help will be appreciated. Thanks in advance.
Old Feb 22, 2007 | 03:41 AM
legal-z's Avatar
i don't think this is normal. i have the same exhaust and it's almost dead center in the hole in the bumper. i'd definitely put on a carbon fiber protector around it. at the very least your bumper will get soot on it and if it's touching, it will probably melt the plastic.
Old Feb 22, 2007 | 04:20 AM
TURBevO8's Avatar
I am sure you can adjust this. I have the 30th Anniversary which is the same with a different can and it is dead center. It took some pulling and tweaking and re-tightening to get it perfect like that though. You should just be able to adjust it.
Old Feb 22, 2007 | 10:53 AM
t51splbb's Avatar
That doesn't sound right. Most problems with fitment on this exhaust are usually because people try to bolt the exhaust together on the floor and mount it without adjustments or they buy it used and the previous owner forgets to include the relocation brackets. Check the link below for reference.
https://www.evolutionm.net/forums/sh...ad.php?t=41891
Old Feb 22, 2007 | 06:25 PM
MiamiEvo8's Avatar
Thanks I will try and loosen it up ans then making little adjustments if I can. I did buy it used but made sure it came with all brackets. Lets see what happens. Thaqnks again
Old Feb 22, 2007 | 06:31 PM
MiamiEvo8's Avatar
Old May 22, 2007 | 02:10 AM
spdrcr456's Avatar
loosen the ring around the muffler by loosening the two Allen heads and turn the ring clockwise while pushing on the muffler to th left and that should do it. when u get it where u want it tighten the allens back up.
MITVRX
Feb 4, 2019 04:26 PM
cjs_evoxgsr
Dec 10, 2012 06:23 AM
Mark T
May 17, 2006 03:19 PM
GngrbrdMR276
11
Apr 3, 2006 08:23 PM
evokw
Jan 29, 2006 10:50 AM
