question on gt30r series turbo.
Old Feb 23, 2007 | 06:13 AM
Cajun Power's Avatar
+1. That is right where I said I would be on the GT30 with an agressive tune measured on a dynojet. That is with the 2.3 too. Mine is still on a 2.0 stock internals.
450-525 on a dynojet with 50 trim or GT30 with meth depending on dyno and tune.
400-450 on dynodynamics
My $0.02
Old Feb 23, 2007 | 06:40 AM
Sti THIS's Avatar
yea im probably going to do a gt30 with meth. Also want to be on a safe tune. 440-450 awhp on meth with a gt30 is safe on a stock internal 2.0 motor, correct?
Old Feb 23, 2007 | 06:42 AM
deadbeatrec's Avatar
safe well thats a touchy subject. anything over 400whp is pushing the limits of stock, but if u have a safe tune then u will be fine. 500whp on stock is where u need to start to worry.
Old Feb 23, 2007 | 07:53 AM
crcain's Avatar
Originally Posted by Cajun Power
Still waiting... 440 is NOT 450. 2.3 is not 2.0....
Someone prove us wrong please.
P.S. It's not going to happen.
2.0 litres make about the same power as the stroked 2.3's right?
Old Feb 23, 2007 | 07:57 AM
scorke's Avatar
Same power 30-40 less ft lbs of tq.
Scorke
Old Feb 23, 2007 | 08:14 AM
EvO6-RS2's Avatar
On my GT30r RnR kit, these are my present results:
On pump (90 octane) and a 50/50 mix (meth/water) I made 399whp & 353 ft. lbs @24psi and turned the boost up to 28 psi on C16 I got 440whp & 400 ft. lbs.
Running AFR's of 11.8 to 11.1.
I will be putting on my Precision GT35r within 2-3 weeks and changing out the cams.
Old Feb 23, 2007 | 08:27 AM
scorke's Avatar
^ Were those numbers on a dynojet?
Scorke
Old Feb 23, 2007 | 11:49 AM
Yes with rod bolts... head studs too if you want to be super safe.
Old Feb 23, 2007 | 03:30 PM
EvO6-RS2's Avatar
Scorke
Dynojet #'s...
