50 Trim guys with ALKY PLEASE LOOK!!!
Hey guys if you own a 50 trim kit and are running alky also what injectors are you running. I was looking to do 780s before the alky but i just recently purchased an alky kit so what size injectors are you running. THanks in advance. Also car will be tuned with safc for now due to not having a tuner near by.
Matt
Matt
ok i havent ordered the 780s yet, I knew that the alky acted as fuel so i would i wouldnt nessacarly need the 780s so what would i need to go with 680s? Or would i beable to pull out enough fuel with the safc with the 780s? Just trying to do it right the first time. I was going to do 780s but throwing the alky into the mix has put that on hold.
780's will be fine, you can always take fuel out; but on maxed injectors you can't add any more... I am on 680's and learned my lesson the hard way, and now i am going to 860's even though they are over kill; i won't have to replace them again for a whiel...
