Cam Install the car is slower and falls on its face.....??
Old Feb 25, 2007 | 08:44 AM
BaLListic_EVO's Avatar
Ok i just yesterday install a set of comp 272 cams a fuel pump and a new timing/balance belt on my car... The problem here is now the car is much slower even after a tune. Its throwing a ton of knock @ about 6k. starts fine idles fine wonder what it could be.... could this be a fuel pickup issue?
Old Feb 25, 2007 | 08:46 AM
Pd1's Avatar
Pd1
Recheck your valve timing.
Old Feb 25, 2007 | 08:47 AM
rraulston's Avatar
it could be that you installed the cam shaft positioning sensor bracket 180 degrees out.......its the metal piece on the end of the exhaust cam....
Old Feb 25, 2007 | 08:48 AM
hmmm checked it twice before i buttoned everything up.... if it was a tooth off seems it would barely run right?
Old Feb 25, 2007 | 08:49 AM
would it still idle normal like that???
Old Feb 25, 2007 | 09:53 AM
Sti THIS's Avatar
its wierd that it still idles normal, it has to have something to do with the timing. If it was a tooth of i should run very very crappy. Like some1 said the cam position sensor might be 180 out, but if you check it, you checked it. GL with everything
Old Feb 25, 2007 | 10:05 AM
yeah i mean the car runs excellent off boost.... im starting to wonder if i have a bad fuel pump might try to reinstall the stocker.
Old Feb 25, 2007 | 10:17 AM
slvrevo's Avatar
sounds like you are off a tooth. happened to me, was getting tuned at shiv's and he noticed the curve dropped off after @4.5k rpm's IIRC. but idled and ran pretty good, just didn't have power up top. double-check your belt/cam gear timing. now, it runs like a champ.
good luck...
slvrevo
Old Feb 25, 2007 | 10:19 AM
EvoTio's Avatar
Yes!! I had that happen on my Talon years ago. The place that had done warranty work at when I snapped my timing belt did that mistake. The car idled great and ran great off boost, but the full throttle power was way down. My car fell off over 5/10's in the 1/4 mile alone. Check out cam position sensor as rraulston suggests.
Old Feb 25, 2007 | 10:24 AM
good luck...
slvrevo
ugh just so happens its raining here today how nice lol no garage
Old Feb 25, 2007 | 03:28 PM
ok problem solved daaaaaamn it pulls good!
Old Feb 25, 2007 | 03:30 PM
RoadSpike's Avatar
What did you fix?
Old Feb 25, 2007 | 04:05 PM
chaotichoax's Avatar
it'd be nice if you shared your fix with us haha
Old Feb 25, 2007 | 04:14 PM
ries's Avatar
ahhhhhhh....what was the problem
Old Feb 25, 2007 | 04:18 PM
Adam J's Avatar
what a tease. he must have just been really excited ha ha
