compression test
Old Feb 26, 2007 | 07:03 AM
ihatepotholes's Avatar
compression test
163-165psi done at freehold mitsubishi dealer
Old Feb 26, 2007 | 07:32 AM
modvp's Avatar
yes!
Old Feb 26, 2007 | 10:18 AM
EvO6-RS2's Avatar
sounds ok
Old Feb 26, 2007 | 11:54 AM
even with cylinder 1 being 10 psi less than others?
Old Feb 26, 2007 | 01:05 PM
Exciting News's Avatar
Are you cranking WOT with a relatively warm engine? If they're within about 10% or so you should be fine.
Old Feb 26, 2007 | 01:26 PM
TVA's Avatar
TVA
IIRC factory compression spec for each cylinder is 160psi +- 5psi with no more than 5psi difference between cylinders. I among others compression tested at 175psi on each cylinder +-1psi per cylinder.
