Stock clutch chatter?
Old Feb 28, 2007 | 04:39 AM
ghoonk's Avatar
Is anyone else here experiencing chatter with the stock clutch?
What causes it, and can it be eliminated?
Old Feb 28, 2007 | 05:27 AM
zwampy's Avatar
I would also like to know. You can hear mine the most when parked while in neutral and you press the clutch pedal in and release.
Mine started after the dealer replaced the synchros and a bunch of other stuff. They now say that it is normal for it to chatter like that.
Old Feb 28, 2007 | 06:01 AM
revvin9k's Avatar
Does is it sound like this? I have an Exedy organic, can't seem to pin point what it is.
http://video.google.com/videoplay?do...17697240842407
Old Feb 28, 2007 | 06:08 AM
NoTec's Avatar
Mine feels funny when its cold and in reverse. Its like a rapid grip to slip alternating sequence. It doesn't make noise in any gear or neutral. I don't race/launch or place any type of excessive strain on my car and it has low mileage. I have just come to accept the quirks of the car.
Old Feb 28, 2007 | 06:11 AM
zwampy's Avatar
You are correct....Personally i like to chalk it up to Character!
joeMama's Avatar
Maybe you guys are having throw out bearing issues
Old Feb 28, 2007 | 06:13 AM
blackevoguy's Avatar
Does it only happen when your stoped with the clutch pedal released? Cuz if thats when it makes noise then its just the throw out bearing. Other then that i dont see how a single plate disk type clutch could chatter
Evo8Master's Avatar
Its normal. I have the same chatter. Especially in the morning when my car is still cold and I just started her up. I just rev the engine, slip the clutch a little and the chatter is gone. There is another ticking noise when the car is in neutral and at idle. That is your throwout bearing in the tranny. Thats normal too. Dsm's had that noise for some time now. Just got to live with these noises
Old Feb 28, 2007 | 06:14 AM
zwampy's Avatar
had those replaced as well...still doing it. It shifts fine and crisp so i'm not worried about it. I wil take it to a diff dealer and see if they say otherwise.
I have a letter from Mitsu stating it's operating as intended so i should be ok if something happens later on.
Old Feb 28, 2007 | 06:22 AM
CBRD's Avatar
i had some weird noises from my ix clutch from when it was new, that i didnt head in other peoples cars.
if its functioning fine, no worries. sometimes u can get frays of the organic materal and that will create noise
cb
Old Feb 28, 2007 | 06:24 AM
deadbeatrec's Avatar
my stock clutch chattered like a SOB, not that i have the ACT HDSS, no chatted what so ever. i also did a prostreetonline flywheel too
Old Feb 28, 2007 | 06:28 AM
JRB_EVO's Avatar
I was also experiencing weird noises when releasing the clutch pedal on really cold mornings (20 or below), now that it is around 30 it doesn't do it anymore. I think it is normal, since now the chattering is gone, and the clutch never stopped working like it should.
Old Feb 28, 2007 | 07:55 AM
ghoonk's Avatar
The chattering on mine only comes on when I let off the gas at higher rpms. It does not happen when I clutch in or not.
Old Feb 28, 2007 | 08:00 AM
hondafan's Avatar
my stock clutch chattered upon starting to move because the flywheel must've been warped(had some blue hot spots on it when i took it out), my aftermarket clutch has the same noise most peoples does, when you let off at higher rpms as they're falling. i thought something was wrong, but even shep says it's normal. he said he mostly experiences it with cars that have aftermarket exhausts, he said something about the sound resonating through it or something, i don't know, just came to accept it.
EvaTheEvo
Feb 6, 2016 07:04 PM
tbaird58
Nov 6, 2015 12:58 PM
Hanzo
54
Aug 24, 2006 08:55 AM
k270kmh
Oct 17, 2004 10:37 PM
