*Two Manual Boost Controller Install Questions*
Old Mar 1, 2007 | 05:28 AM
LIL EVOL's Avatar
They're legit. Gone through most threads already. Installed my Hallman Pro RX MBC last night. Input to turbo nipple, and output to WGA nipple. I capped the input nipple on the stock boost control solenoid like in this picture of JSCSpeed's write-up from Hallman (reference step 5, the hose with the dotted line): http://www.hallmanboostcontroller.com/howto.html
Should I leave this dotted hose in-place connected to the nipple on the stock intake tube or cap both off? Most references show both boost control solenoid nipples and the nipple on the intake tube capped and tube removed. Just confirming it won't hamper the effectiveness of my MBC. Currently running 20psi and will spike to 21psi. Started at about 11psi turned all the way down. I thought there was a restrictor pill in the dotted hose as well. Thanks, just following up on my install.
Old Mar 1, 2007 | 06:00 AM
LIL EVOL's Avatar
MODs please delete...wrong section...my bad
