Rear Diff Specs (Poss. Sticky)
Old Mar 1, 2007 | 08:03 AM
joeMama's Avatar
I am in the process of rebuilding my rear diff. and I just wanted to share some of the info I have aquired, I searched this and other forums and really found nothing so this is for the little people! ..
Ring Gear Backlash: .006 of an inch
Carrier Bearing Pre-load: .010 of an inch
Torque Specs:
Pinion Gear: 45ft lbs
Bearing Caps: 150ft lbs
Pinion Depth: Unfortunatley to set the pinion depth properly the rear must be set-up then painted and run(the paint will show you how the gears are meshing and if there are any clearance issues), to check for proper mesh and anlignment. It takes some time, but the end result is a nice even running gear.
I hope this information helps someone out
Old May 3, 2014 | 08:43 AM
allevolution's Avatar
Just thought I should mention this information is incorrect. Not sure if it was you or someone else that added this to the official torque spec thread.
Rear diff bearing caps are 27 +-1 ft lbs
SKY888
May 8, 2018 01:44 PM
fabilloPR
Apr 24, 2016 05:45 AM
desertsoldier22
Feb 17, 2016 08:51 AM
balla48801
18
Oct 28, 2014 05:42 PM
balla48801
Oct 7, 2014 09:09 PM
